Can anyone give me some advice the best way to cut chrome trim so the edges are nice, straight and smooth like the ones that are on there currently. I tried an utility knife but it just isn’t cutting it.
Thank you,
Thank you,
I assume your talking flexible T mounding around the head. I cut chrome trim for my Avatar LE one time and recalling trying to get it 100% perfect with no luck. Once I installed this it, I was happy with the outcome just the same.
You might be able to replicate a grove to put the end in so the trim lays flat. Cut across with a straight edge, remove from groove and cut the back spine of t-molding.
I simply used a standard blade. I laid the channel on its side and just took my time cutting especially towards the end. Knock off any little burrs with some fine sand paper
Quoted from Toasterdog:I assume your talking flexible T mounding around the head. I cut chrome trim for my Avatar LE one time and recalling trying to get it 100% perfect with no luck. Once I installed this it, I was happy with the outcome just the same.
I will try this. Any special blades.
Fresh razor blade works great - press through like you would butter... don't 'saw'
Support the piece where you are cutting
You don't really want to glue it in if you don't have to. Right sized T-molding stays in with friction. If it's too small... just use some hotglue dabs here and there to help tighten it up. like every 8" or so.
This page was printed from https://pinside.com/pinball/forum/topic/cutting-cutting-chrome-trim and we tried optimising it for printing. Some page elements may have been deliberately hidden.
