Quoted from mr2xbass:it CAN be as simple as replacing the existing single switch with a dual switch. Not a dual contact switch, but a dual switch with two sets of blades that can be triggered by one actuator. One set gets the wires that the original switch had, the other set goes to the WT
Yes, if there isn't already a dual contact switch somewhere, you can replace a single with a double. Even then that can get pretty expensive (single leaf switches are pricey as it is)
http://www.pinballlife.com/index.php?p=product&id=152
that's why many opt to build their own separate cherry switch with an arm, because cherry switches are very cheap (as low as a buck)
