We're back!
After a disaster in our datacenter took down our server, we are now running Pinside on a brand new server. However, things may not work as expected as we are still polishing the playfield and adjusting some switches! We might be switching to maintenance mode a few times. Please see this forum topic for more info.
(Topic ID: 153445)
Custom sound and music for gottlieb 80b and system 3 - oh go on then
By applejuice
5 years ago
  • 60 posts
  • 29 Pinsiders participating
  • Latest reply 1 year ago by Luzur
  • Topic is favorited by 32 Pinsiders
    There are 60 posts in this topic. You are on page 1 of 2.
    #1 5 years ago
    Whilst working on my 80b sound board recreation and building up the different channel sections, i came up with an idea to build a version for adding your own sounds, speech and music into a board that would still plug into existing technology. Powered by other similar technology that i am already using in some of my other projects and products here's a sneak peek of the early prototype
    The idea being that you will be able to load a set of sound files in WAV format on to an sd card which will then alter what your game plays during the game etc. The games have 31 different sounds that can be played including 7 music tracks
    #2 5 years ago
    It would be a nice improvement, would it also cover System 80A?
    #3 5 years ago
    pretty cool
    #4 5 years ago
    I can dig it! System 80Bs and early System 3s always sounded wayyy too "tinny" for my liking. It'd be nice to have a way to upgrade these sounds
    #5 5 years ago
    YUUUSSSSHHHHHH!!!!!!
    #6 5 years ago
    So will this have the option of choosing between using alternate sounds and the original sound generators and being able to change back and forth?
    I currently building something similar, just for custom sounds though, using an Arduino and robertsonics WAV Trigger ( www.sparkfun.com )
    1 month later
    #7 5 years ago
    Latest updates for my custom sound board for 80b games. Some pics of the latest revision to the proto board using some more powerful embedded controllers to handle the sound processing better. The board can now play upto 4 channels of 44khz, 16 bit, stereo sound (cd quality) sound. So that's enough for 1 music channel, 2 sound effects channels and 1 speech channel. I have the board playing the original sound effects and music from gold wings via wav file samples read directly of sd card and of course you could swap these out for original score and effects etc. The possibilities here are endless.
    The board is also instant boot using embedded controllers. no computer os system boot up delays. More vids soon when i plug this into my gold wings game and play some games to test it out.
    #8 5 years ago
    This is cool. I could program my Raven to play "Get to tha choppa!" when the helicopter spins & "Long Tall Sally" when the ball drains (amongst other things).
    Any idea what the cost would be?
    #9 5 years ago
    Quoted from Topher5000:
    Yep, that's the plan Aiming to sell them for around £100 plus postage, though that's not finalised yet.
    2 months later
    #10 4 years ago
    I love that you are doing this - I've been hoping to add custom sounds to my Arena ever since I got the game... (Conan the Barbarian excerpts!) Any new developments/progress?
    #11 4 years ago
    Quoted from Vongoosewink:
    Still working on it. The more powerful controller i'm using now is much better. Things have been hectic with all my other hardware board sets and projects, but this is on the list.
    #12 4 years ago
    Quoted from applejuice:
    Still working on it
    YAY!
    #13 4 years ago
    someone that owned a gold wings could retheme into a top gun pretty easy
    #14 4 years ago
    Quoted from toyotaboy:
    I own a Gold Wings ! One of my fav games of all time and the reason why i started making new cpu boards and these other projects Thanks JT. You rock
    #15 4 years ago
    How would it play stereo sound? Do you have an added amp section so we can add a speaker? My Raven is my first Gottlieb and it only has one back box speaker, I assumed the other System B's would be the same.
    #16 4 years ago
    Quoted from Geocab:
    The board has the capability to decode stereo sound files, but to be compatible with stock game wiring and amps it outputs a combined mono signal. I may develop a true stereo amp board that can be plugged in as a replacement though later Most pinball games though are mono and original sound files are usually only recorded in mono. A good upgrade for general gottlieb 80b games is to add another speaker to the backbox anyway just to balance the sound output and return the game to a more normal 3 speaker design.
    The board has 4 channel but this is mainly for handling the types of sound and speech effects playing together during the game. i.e you can play a music backing track then 3 other sound effects potentially at the same time. The original boards hardware is very good, so that it can handle the same and not have some sounds cutting others out.
    Taking this in game play terms. The multiball ready feature on Gold Wings has a high pitched bip repeat tied to a flasher to show the lane to shoot. This plays along with the background music in a 1 second repeat. However, when pop bumpers and other targets are hit they also still respond with their appropriate sound without stopping any other sound playing
    #17 4 years ago
    Cool. Thanks for the explanation.
    #18 4 years ago
    Yeah, I noticed on Spring Break, the background music has three voices (bass, melody, accompany/harmony) and a drum beat. The music plays non-stop during the game BUT anytime there is a sound effect triggered, it is generated by the same channel that does the drums (noise generator). So the music continues to play but the noise channel goes back and forth between the drum part for the background music and whatever sound effect is being triggered by hitting switches on the play field.
    #19 4 years ago
    I might have kept my Gold Wings if this was available.
    8 months later
    #20 4 years ago
    Any updates?
    #21 4 years ago
    Yes still working on it. Hope to update again soon
    #22 4 years ago
    During the mid-1980s when Williams and Bally were doing speech on every game (around the Space Shuttle and forward era), Gottlieb was not doing speech (to save money no doubt.) A lot of sys80b games could really use speech. Raven, Gold Wings, Hollywood heat, just to name a few. Basically all the games from 1983 up till about 1988 by Gottlieb did not have speech (and sure could use it.)
    That said though, someone would have to *record* the speech. Your board looks like a great way to implement said speech, but getting an appropriate voice actor to do it (and writing the lines), well, that's another story. Otherwise you end up with the speech like on Americas Most Haunted (which seems odd and out of place.)
    What i'm saying is there's a lot more to this then just playing the speech! The example of Raven using the Arnold line, "get to the choppa", sounds good. But i'm not sure how it would play in the context of the game. It might be a bit weird, especially if the speech is "too good", compared to the rest of the game's sound track. Just something to think about...
    1 month later
    #23 3 years ago
    Imagine Hollywood Heat with Miami Vice speech and music..... *drools*
    #24 3 years ago
    Quoted from Luzur:
    Exactly would I would like to do with mine.
    5 months later
    #25 3 years ago
    Major progress with this project. I have finally got the interface to work reliably with inbound cpu requests.
    Good point in the vid is around 5.35
    This project has been much more complex than first thought but we are getting there now. The sound board logic is much more than just 'play this sound Id' it turns out
    I'm still refining the code logic and not 100% sure if each game will need custom logic as well as a sound file set, we will see, but the second prototype boards are getting closer. Also waiting for some dac sound processors to improve sound quality and remove noise. The first test was using bog standard passive Pwm line out
    1 month later
    #26 3 years ago
    So how long before you can do complete sound/music remakes?
    #27 3 years ago
    Quoted from Luzur:
    Not long! I am currently working out the best DAC system to use to get the clearest sound output possible
    2 months later
    #28 3 years ago
    So, how goes it? any updates?
    #29 3 years ago
    His looks really promising! I would definitely be interested.
    9 months later
    #30 2 years ago
    Did you get any further with this?
    #31 2 years ago
    Quoted from Linkage:
    Yes i have been working on this alongside many other projects . Here is the latest prototype boards i got just before christmas. This is part way through assembly of it for testing. Its alot smaller than the original now but still fits the mounts ok.
    1 month later
    #32 2 years ago
    This is an incredible project! Any update?
    I’m curious if this is going to be something that will be available for others (me) to purchase? Amazing possibilities with this!
    #33 2 years ago
    Will this work on System 80 games or 80b only?
    #34 2 years ago
    Pardon my ignorance but would this work on a barb wire?
    #35 2 years ago
    Looks great. I have a gold wings and a Gottlieb Rock, Would be great to add my own music tracks to these games.
    #36 2 years ago
    Any update
    1 month later
    #37 1 year ago
    Sign me up for one when available
    #38 1 year ago
    Quoted from yotsuya:
    Me too
    1 month later
    #39 1 year ago
    Same here.
    3 weeks later
    #40 1 year ago
    Any developments?
    #41 1 year ago
    Any news?
    #42 1 year ago
    I really hope this works out. I'd buy like 3 of them.
    #43 1 year ago
    Quoted from TwoHeartedMale:
    I also really hope this works out.
    Edit: Just 80B? Or 80A and 80B? Thanks.
    #44 1 year ago
    Is this happening or what?
    #45 1 year ago
    #46 1 year ago
    Questions,
    1. Based on images you posted on posts 1, 7, and 31, is it correct to assume that your soundboard will only replace the A6 versions in games listed in images 2-5(see attached image)*
    2. To further clarify, will your board work in all of the games listed in images* 2-5 or will it only work in one of those versions?
    Thanks,
    Phil
    *Image is a screen shot form Pinball Resource
    #47 1 year ago
    You do notice they are all different part numbers?
    #48 1 year ago
    Yes I noticed, but since he had stated which one he was working on and others had ask general questions I thought I would be a bit more specific. Apologies if my question bothered you.
    #49 1 year ago
    Trying to help, not bothered.
    weird.
    #50 1 year ago
    Quoted from BleacherBum:
    Questions,
    Thanks,
    Phil
    *Image is a screen shot form Pinball Resource[quoted image]
    Its mainly designed for a replacement of boards MA766 and MA866 but should work with other games that use flavours of either of these boards.
    Quoted from Psw757:
    When i have something to share i will update the thread. I work on many different projects at once and there is only so much time in each day, plus i'm just 1 guy, not a hundreds strong enterprise like stern or something...
