I found this diablo(getaway car) on ebay. I found an awesome place to put it. On the shooter lane plastic part. Only tools needed is a small drill/bit and a Phillips screw driver. Take car out of plastic case/cover. Turn car over and locate the single screw on the bottom of the stand. Remove the screw (releasing car from stand) and set aside, (screw will be reused). Remove the top shooter lane plastic with the speed limit 65 on it.2 screws on either side. Take your small drill/ bit (same diameter as the screw you set aside) and gently drill hole as shown. Put car ontop of plastic part and secure car with the supplied screw, from the bottom of the part into the bottom of the car. Just snug(do not over tighten). Reinstall plastic part with car on top. Job done. ENJOY!
20210319_205041.jpg20210319_205054.jpg20210319_205101.jpg20210319_205317.jpg20210319_205335.jpg20210319_205422.jpg20210319_205435.jpg20210319_205518.jpgphotostudio_1616206428386.jpg
