Hi guys
I know alot of you can't help me but maybe someone that has done a project can help me.
I have been wanting to do a custom pin for a while but my biggest hesitation is the programming side of things as have zero experience.
I want to do a re-theme using just a 80's Bally playfield including it's parts but in a 90's bally/wms cabinet with a dmd at the back of the playfield like on CV. I only have a unpopulated playfield and populated playfield of the same and both damaged so ideal for a re-theme (sorry keeping the theme quiet at this stage), but no cabinet nor board set etc but I want to do totally different rules etc.
I have searched for a while and so far only found 2 systems with Ben Heck releasing one soon (I hope) and they use different programming options.
Pinterface
http://www.millisoft.de/pinterface_en.php
P-Roc
http://www.pinballcontrollers.com
Ben Hecks
???? at this stage
Is there any others?
Also my fear is I inject alot of time building a game and designing graphics and doing wiring and then I come to a grinding halt due to programming dramas becuase of no experience.
P-Roc appears to be the leader / most well known but experience needed to programme.
Pinterface has 2 options to program, one via the typical programming technique and the other via a graphical technique which seems better for the inexperienced. My concern with this product is it isn't really known and hardly anything on youtube of a working example. If you download the pdf manual, it explains alot and seems very good and more user friendly.
Ben - if you are reading this, if and when you release your system could / would you consider a graphical software option for programming for the wanna be pinball geeks that don't know how to programme.
Can anyone help with advise, experience, links anything please, then I can start my project and share with you guys my plans.
Thanks in advance
