(Topic ID: 249521)
Custom Apron Cards - (Printable Versions Only)
By Coindropper
2 years ago
  • 1,259 posts
  • 242 Pinsiders participating
  • Latest reply 7 days ago by Spiderpin
  • Topic is favorited by 479 Pinsiders
GOTG-Cards-PDF.pdf (PDF preview)
41 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 1259 posts in this topic. You are on page 25 of 26.
#1201 3 months ago
#1202 3 months ago
These are AWESOME!! Just one question. How do you print them to be the correct size? I keep trying but the sizing is wrong... Also what's the best way to download the images to get the highest quality? Thanks!!
#1203 3 months ago
Quoted from JohnnyGee:
Get the dimension from incochnito's site.
Make it happen in any word or photo processor program.
#1204 3 months ago
Or read the first post?
#1205 3 months ago
Quoted from bigfoot53:
VIKING.[quoted image][quoted image]
Hey bud, these are awesome! But they’re low quality, do you have the originals to upload?
#1206 3 months ago
Quoted from Carny_Priest:
As mentioned the batch script is here:
https://www.dropbox.com/s/vlqxqy7ieu3qcmr/ConvertPrintSize.ahk?dl=0
This does require Windows.
It uses AutoHotkey, a Windows scripting language. You will need to install it. It is open source and free.
https://www.autohotkey.com/
Image processing requires ImageMagick. Again, it is open source and free. I typically use a portable distribution.
https://imagemagick.org/
The script assumes that you simply unzip the contents of the portable distribution to a folder C:\imagemagick. If you want to use a different folder, you can change the path in line 13 in the script. You can certainly use the installer version of ImageMagick and I'm thinking that you can simply delete out "%ImageMagick_Path%\" from line 67 in the script. The script is just text and you can edit using Notepad.
I've organized the card images by table. Typically, I would copy the script to a folder with a table's images. I would use the Command Prompt. Navigate to the folder and type
ConvertPrintSize.ahk followed by the table manufacturer
Ex. "CovertPrintSize.ahk Stern"
Allowable manufacturers are
AlvinG
Bally
DataEast
Sega
Stern
Williams
As the template for Gottlieb is already correctly sized you will get a message
Anything else, misspellings, or no manufacturer will give you a message
The program will create an "out" folder within the same folder as the script. It loop through and for each image, save converted images to the out folder with the same name. No changes are made to the original image.
You may not want to deal with a command prompt. If not, you can open the script in Notepad and in line 18 change %1% to the manufacturer for the table whose images you want to convert. That should work. Run it from Windows Explorer (i.e., double click ConvertPrintSize.ahk).
Hope this helps.
So if I understand this correctly, what he is trying to say is:
如前所述,批處理腳本在這裡:
這確實需要 Windows。
它使用 AutoHotkey,一種 Windows 腳本語言。您將需要安裝它。它是開源和免費的。
圖像處理需要 ImageMagick。同樣,它是開源且免費的。我通常使用便攜式發行版。
該腳本假定您只是將便攜式發行版的內容解壓縮到文件夾 C:\imagemagick。如果要使用不同的文件夾,可以更改腳本第 13 行中的路徑。您當然可以使用 ImageMagick 的安裝程序版本,我認為您可以簡單地從腳本的第 67 行中刪除“%ImageMagick_Path%\”。該腳本只是文本,您可以使用記事本進行編輯。
我已經按表格組織了卡片圖像。通常,我會將腳本複製到包含表格圖像的文件夾中。我會使用命令提示符。導航到文件夾並鍵入
ConvertPrintSize.ahk 後跟表製造商
前任。 "CovertPrintSize.ahk 斯特恩"
允許的製造商是
阿爾文
巴利
數據東方
世嘉
斯特恩
威廉姆斯
由於 Gottlieb 的模板大小已經正確,您將收到一條消息
其他任何內容、拼寫錯誤或沒有製造商會給您消息
該程序將在與腳本相同的文件夾中創建一個“out”文件夾。它循環遍歷每個圖像,將轉換後的圖像保存到具有相同名稱的輸出文件夾中。不會對原始圖像進行任何更改。
您可能不想處理命令提示符。如果沒有,您可以在記事本中打開腳本,然後在第 18 行將 %1% 更改為要轉換其圖像的表的製造商。那應該工作。從 Windows 資源管理器運行它(即雙擊 ConvertPrintSize.ahk)。
希望這可以幫助
#1207 3 months ago
Quoted from rcbrown316:
如前所述,批處理腳本在這裡:
這確實需要 Windows。
允許的製造商是
阿爾文
巴利
數據東方
世嘉
斯特恩
威廉姆斯
希望這可以幫助
In other words. there is no way i am figuring this out without someone explaining what to do in a step by step format as if they were speaking to a 6 year old.
#1208 3 months ago
OK,
Aliens by Pinball Brothers are arriving as we speak. The apron cards need a serious update. If you could be so kind!!
#1209 3 months ago
^^^^^Indeed. Please put some more Aliens on our Alien. Thanks!
#1210 3 months ago
Quoted from Lethal_Inc:
Yep !
#1211 89 days ago
Is there a specific reason people (apron card creators) dont just create PDF's or images containing the 2 apron cards, to print out directly without any scaling or image fiddling necessary? It seems it would be a far easier choice for the users when printing.
I know this is done on other sites offering apron cards.
Please dont get me wrong, i think the time and effort put into this by Coindropper and others is AWESOME. I Was truly just wondering about the printing / scaling issues a lot of people seem to have...
#1212 89 days ago
Quoted from Phantasize:
Good question. I have given up attempting these until I can find a 1, 2, 3 approach.
#1213 89 days ago
Apart from the fact that many don't even create the cards in the proper dimensions to start with, there are also potential issues with PDF files. Most people don't understand proper compression settings (i.e. disabling them, etc.) when creating high quality files. Also, many people will still screw up the printing by having "Fit" or "Shrink Oversized Pages" set in their PDF printer dialog. Then there's the issue with print media if using smaller photo paper. How does the average user figure out how to print a letter sized page with two images on two different 4x6 or 5x7 pieces of photo paper?
Bottom line, is if you want freebies, it's going to take a little work for users to print them. Of course, you could always have me make them for you - perfect size and quality every time. Shameless plug for my cards at http://aproncards.com, and I will also produce cards from any available designs for buyers.
#1214 89 days ago
Paging Mr. Coindropper: We need some of your sweet cards for Stern Mandalorian asap. Need both Pro/Premium with orange accents, and a set of LE cards with Beskar gray accents(boarder?)
Thanks in advance
#1215 89 days ago
Would love to see one for a 1972 Gottlieb Grand Slam. I have one with the original cards. Looks great, but after painting the cab and cleaning everything up...they look out of place.
#1216 89 days ago
I went to a local print shop and they figured it out. Eventually.
#1217 89 days ago
I'm fucking hopeless and i figured it out.
22
#1218 89 days ago
The Mandalorian
Slide1.JPGSlide10.JPGSlide11.JPGSlide12.JPGSlide13.JPGSlide14.JPGSlide15.JPGSlide2.JPGSlide3.JPGSlide4.JPGSlide5.JPGSlide6.JPGSlide7.JPGSlide8.JPGSlide9.JPG
#1219 89 days ago
Quoted from Coindropper:
The Mandalorian
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
AMAZING!
#1220 89 days ago
Well Done Sir!
Coindropper is da man!
#1221 89 days ago
What happened to your Hoff?
#1222 89 days ago
Quoted from punkin:
The Gif was not working right-tried to get the Hoff in there!
#1223 89 days ago
You have to add the gif using this drop box. Just select gif full sized.
#1224 89 days ago
Quoted from punkin:
The Hoff is in da house!
The Hoff approves!
#1225 68 days ago
I just picked up a Robo War this past weekend, Anyone have a cool apron design to share?
#1226 65 days ago
I love these cards, but also have not ever been able to print any at the correct size.
It’s a bummer, but I just moved on.
#1227 65 days ago
AlvinG
Bally
DataEast
Sega
Stern
Williams
Hope this helps.
So I ran this for a Stern and the out folder contains the image, but the same size as the original 4000 x 2250; I'm assuming that's not correct and something is not running correctly?
#1228 64 days ago
Quoted from Nevus:
When printing these kind of cards, I also struggled with sizing. The cutout in a Stern machine is made for a card which is 75mm x 140mm, or about 3-inches by 5.5-inches. Then there is the issue with printing itself. My inkjet color printers are never perfect in color gradation, and i doubt most people own a color laser printer.
So what I do is grab the card images I want and then I use POWERPOINT to setup an 8-1/2 inch x 11-inch page and I drop the images onto that page, making sure to size the card image to the 3x5.5 size discussed above. Powerpoint has a virtual ruler, so it's easy to pull and stretch whatever image you have to make it exactly 3x5.5 in size. The final step is to allow Powerpoint to SAVE AS JPG, which gives you a 8.5 x 11 inch JPG that has all the cards sized correctly, and I send it over to FEDEX/KINKOs to print in vivid color on the 'waterproof .7' specialty stock for about $2
Sounds complicated, but it's really not. The result is a perfectly printed page of cards (3 fit on a page), that I can pickup at my local KINKOs shop, in about an hour or two, and they have no minimum. I then manually cut the cards from the page, and Viola'. (Even simpler: Ask Mr_Tantrum to do all of this for you and he'll ship it to your house in a few days! It's not very expensive.)
If anyone wants to see a sample of the edittable GOTG page I just created in Powerpoint, let me know and I can share it.
GOTG-Cards-PDF.pdf
#1229 64 days ago
Good idea by Markharris2000 to use PP for those who don't have graphics software. However, you don't actually need to use the ruler if you past image into PowerPoint (or Word) if you want to print your own cards with accurate sizing.
In PowerPoint . . .
- Create a new presentation
- Click on "Design" on menu bar
- Click Slide Size on ribbon bar and select custom slide size
- Set width at 8" and height at 10.5" (to allow for print margin) and click OK button (if prompted select Ensure Fit)
- Import image and align to page then right click on it > Format Picture > Size & Properties > Size
- uncheck Lock aspect ration
- set dimensions as desired
Repeat process for as many cards as you want/will fit on a page. To add more cards, just add additional page(s) to PowerPoint.
Typical card sizes are as follows:
Stern | 5.5" x 2.875"
Bally | 5.5" x 3.25"
Williams | 6" x 3.25"
Data East | 5.5" x 3.0"
Gottlieb (large) | 6" x 4.25"
Gottlieb (small) | 6" x 2.3125"
Spooky | 6" x 3.25"
If you don't want to make your own or don't have the tools to do so, then you can always order from me as I'll make any cards (my design or someone else's). I use heavy OEM ultragloss photo paper, a six ink photo printer with OEM inks, and coat all of my cards with a clear gloss vinyl. You can see example cards here: http://aproncards.com
Added 63 days ago:
BTW, these are the sizes for the vast majority of cards produced by these manufactures. However, there are also manufacturer oddballs for each. The first step before sizing your cards is to measure the OEM ones that came with the pin.
#1230 64 days ago
I take the stock apron card that came with the machine and a 300dpi image of what I want printed down to a commercial print shop. I tell them to print me a high quality card to the size of the stock card. They charge me like $3.50 USD and it takes them a few minutes. They use color laser printers of course.
#1231 64 days ago
My canon color laser does a very good job, and it wasn't expensive.
I use it to make tons of reproduction pinball stickers for my restorations, if i cant get them.
#1232 64 days ago
Thanks again Coindropper, The Mandalorian cards you made are so much better than the stock ones...
#1233 64 days ago
#1234 64 days ago
Cool image. Make an apron card out of it please. Just need another one for Aliens for the other side maybe?
#1235 63 days ago
Mr_Tantrum and Markharris2000
Thank you both for your tips. I used Google Slides this morning and generated a good test set of AMH cards. It looks like Spooky used a different size for AMH. 6" x 3.25 seems to match on my TNA, but is too large for AMH. I'm going to search today for the right size.
I do actually have a color laser printer at home and can print to glossy card stock after I get it right.
#1236 63 days ago
Quoted from Nevus:
Why not measure the ones in it? Save a search, we are running out of searches.
#1237 63 days ago
The original AMH had no cards. I can measure the apron and eyeball it.
#1238 63 days ago
Quoted from Nevus:
I didn't know. My Fathom mermaid will be the same when it comes, no cards.
#1239 61 days ago
Here are a few I threw together on a request for another user. I tried to use the manual he sent for the rules, but never heard back from him if these looked right since I have never seen or played the game.
ALIEN 1.JPGALIEN 2.JPGALIEN 10.JPGALIEN 11.JPGALIEN 5.JPGALIEN 3.JPGALIEN 4.JPGALIEN 7.JPGALIEN 6.JPGALIEN 8.JPGALIEN 9.JPG
#1240 61 days ago
Beautiful work!
#1241 61 days ago
Awesome!!!
Thank you so much! You're a prince!
#1242 61 days ago
if anyone has this mastered and wants to print a bunch of these and sell them to me hit me up on PM. I'm done screwing with it. It will end up being about 8 sets.
#1243 61 days ago
Just measure the size you need, post the image in word, set the size to what you measured. Print
#1244 51 days ago
The Pinball Brothers 'Alien Remake' does not have an extra ball button. It just uses the Launch button in place of it.
#1245 45 days ago
Paging Mr. Coindropper...
Need some of Coindroppers custom cards for Gladiators and Barb Wire. (I also had the thought of having someone make an alternative Barb Wire translight using one of the comic versions and cards that may tie in?) If anyone has ideas or has done so?
#1246 43 days ago
Any cards for Bally Space Invaders?
#1247 36 days ago
Not sure if I missed it, but are there any custom cards for Stern’s High Roller Casino?
Thanks,
Jason
#1248 35 days ago
Quoted from Yoeddy:
Thanks,
Jason
First post has an index.
#1249 35 days ago
Quoted from punkin:
Found em! Thanks!
Jason
#1250 35 days ago
Any Dirty Harry apron cards out there ?
