Lots of work these last few days. One of the problems with the machine is that ALI used a lockdown bar that mounts into the front wood of the cab like the old Bally bars of the 60's did. The machine didn't come with the lockdown bar so I had to mod a Williams or Bally bar to fit which then shortened the playfield glass length so that a custom glass would be needed.
In playing with a glass in place it has become apparent that the light colors from the head TV movies cause too much glare on the upper portions of the playfield glass so I talked with wallybgood and decided to order a sheet of Invisiglass for the machine. Since tempered glass cannot be cut I had my son help me pull the head and then used a 1/4" and 3/4" chisel to lengthen the glass run by about 7/8" so that a full sized sheet will fit. I also took advantage of the removed head to fix the back plate that had come loose.
The other day I had a conference call with Onevox and his printer in NC about having the playfield direct substrate printed. The printer has a multicolor latex machine that uses a vacuum to hold the piece down and the machine can print on wood. We spent about half an hour going over the process to bring the printer up to speed about the various aspects of printing a pinball playfield. In the end they think that their print can go over shellac and that it should be compatible with Spraymax 2K.
To test the process I am making three small playfield sections with an insert and saucer hole and we will do trials of printing onto these. The printer will then send them back to me for clear coating and once we feel confident in the process, I'll send them the two playfields that I'm making. While I was sanding down the inserts I thought that I'd mention a technique that is used in wood working that maybe some won't have seen.
One way to be sure that you've sanded an uneven area down is to make pencil marks across the area and once all of the marks are gone, then the area should be flat. Also since I'm using a hand held random orbit sander and not a thickness sander, the marks will let me know if I'm taking off more on one side of the insert than another since the sander can rock on the insert. Here are three photos demonstrating how this works.
20210729_154114 (resized).jpg20210729_154208 (resized).jpg20210729_154330 (resized).jpg
