(Topic ID: 102062)
Cult of Evaporust
By Cheddar
5 years ago
  • 214 posts
  • 85 Pinsiders participating
  • Latest reply 4 months ago by cmack750
  • Topic is favorited by 82 Pinsiders
    There have been 64 images uploaded to this topic. (View topic image gallery).
    7 key posts have been marked in this topic (Show topic index)
    There are 214 posts in this topic. You are on page 4 of 5.
    #151 3 years ago
    Quoted from CoitusMysterioso:
    But looking on the positive side you just found a cheap way to get black balls! I wonder if you painted a design on the ball first would it leave that spot shiny afterwards.
    Could be a cool way to make custom balls!
    Better (more durable) way of creating dark balls: Heat them with a blow torch and drop them in motor oil.
    #152 3 years ago
    #153 3 years ago
    So, I've got a major project game that needs tons of love. It was stored in a damp environment, so the cabinet was a total loss, and there's rust on a fair number of parts.
    The wiring matrices have been removed, and the lamp sockets on the GI line are in bad shape. A few segments were separate from the main run, and I decided to use Metal Rescue (which seems to me is the same as Evaporust for all intents and purposes) to see if I could salvage them. Sure enough, the sockets cleaned up perfectly. (didn't have the forethought to take a "before" photo) I hit them with Boeshield to keep them from rusting again and felt pretty sporty.
    So...the next step would be to go ahead and bathe the whole rest of the GI line in the same way. My question for the panel is, some of the bulbs on this line are on lamp boards - would Metal Rescue damage those boards? It would save a ton of work to simply be able to dunk the whole loom of wiring rather than clip off and re-solder all the lamp sockets...
    #154 3 years ago
    Quoted from sethbenjamin:
    I would dunk the entire loom and afterwards bake it in the oven at the lowest setting.
    2 months later
    #155 3 years ago
    Just became a cult member. This is not an elaborate hoax; the pictures are real! I saw the before and after pics, but in the back of my mind was the tickle of a doubt. No more. I'm now looking for other stuff to dunk.
    #156 3 years ago
    I had a set of legs come in on a pin that were completely orange - no joke, I thought they were unsalvageable.
    I left them in an evaporust tube for about 2 weeks (other stuff got in the way; not sure if it needed the full 2 weeks) and.. sparkling shiny. I had not polished them or scrubbed st all except I wiped them down with a bit of aluminum foil to clean the goop off. No pitting really either!
    I did still have to use PB Blaster to unfreeze the levellers (and replaced those). Still - The cult is real! Lol
    #157 3 years ago
    Quoted from Lame33:
    It's good shit, Maynard
    1 month later
    3 weeks later
    #159 3 years ago
    You can currently get this for $13.99/gal at Pep Boys with promo code MMJ30 (good thru 8/7). Buy two to get free shipping!
    https://www.pepboys.com/product/details/206426/00739?CID=358129_affiliate
    #160 2 years ago
    Quoted from SirScott:
    great heads up. awesome deal. just bought 4.
    2 months later
    #161 2 years ago
    I’m tackling the same issue right now. I’ve got some evapo-rust coming, but interested to know how to protect the socket afterwards? Wouldn’t some like boeshield effect the inside of the socket?
    1 month later
    #163 2 years ago
    It's $88 AUD for 5 litres here.
    #164 2 years ago
    If there is still anyone on the fence about this stuff, don't be. This is one of my top 5 favorite things I use. I've even bought a gallon for my dad (who likes to fix old tools) and mother-in-law (who restores old sewing machines).
    #165 2 years ago
    Quoted from comment23:
    THIS!!! I am using some as we speak on a Bally chime unit, lockdown bar assembly, and brackets. Evap is my go to next to Muriatic Acid.
    -1
    #166 2 years ago
    Thanks for the heads up! Note: $13/gallon is actually $13.99/gallon --> $14/gallon. Or, $14.97/gallon after tax. So, $15/gallon. Still a good price, and I was due for a fresh gallon anyway.
    #167 2 years ago
    Quoted from SkyKing2301:
    Don't spill any, or you will be looking at $16 a gallon
    #168 2 years ago
    I was a skeptic at first but I've used Evapo rust twice now for rusted legs and it works so well. No more scrubbing, sanding or grinding...submerged these legs for 24 hours in my 4" pvc pipe.
    Before and after.
    #169 2 years ago
    Quoted from sagejr:
    Before and after.
    I think you mean after and before
    #170 2 years ago
    It doesn’t seem to work very well on the levelers, at least in my experience - anybody know why?
    I had a pair of legs that the levelers were rusted on so tight and I did not remove them before dipping them in Evaporust.. never got ‘em off so those legs are just sitting. The legs looks great but levelers look chewed up like hell. I tried PB Blaster and everything.
    #171 2 years ago
    Leg levelers typically frequently get wet from people mopping the floor. They also get covered in floor wax (on route locations). I have found that levelers which are rusted stuck in the leg threads, leave the legs soak for two weeks in the Evapo-Rust. That generally gets the rust in the threads disolved enough to get the old levelers out.
    For the cost of new levelers, it's better just to throw the old ones away and install new ones after removing the legs from the Evapo-Rust.
    #172 2 years ago
    Quoted from wxforecaster:
    Right, the pictures were in the correct order before I sent the post but then re-ordered. Pinside always seems to get the pictures backward.
    Quoted from KenLayton:
    True, I never bother with the old levelers. These will be removed and replaced with new ones.
    Evapo Rust is good stuff....I bought 2 gallons on sale at pep boys for 13.99 each. Re-usable too. I just use a coffee filter to strain out the particles and pour it back into the original containers when I'm done.
    #173 2 years ago
    Quoted from tomds:
    Hey, sorry, I didn't catch your reply until now, but I can tell you that I submerged all the backglass lamps and wire braid as well as all the playfield GI sockets, let them dry, doused them all with Boeshield and all work fine (got the game up and running back in July).
    I actually went one step further; once the Boeshield was dry, I put old bulbs in the sockets and shot everything with clearcoat for added protection. This was my process for all metal parts under the playfield and they really cleaned up beautifully.
    #174 2 years ago
    I agree - my problem was a frozen set of levelers which even for a genuine month in evaporust, were not movable. I wasn’t trying to save the levelers, but indeed the legs which are useless if you can’t adjust due to frozen levelers. Interesting all the abuse they get!
    #175 2 years ago
    Quoted from Rdoyle1978:
    Heat from a torch on the threads will work
    #176 2 years ago
    Quoted from sohchx:
    Damn! I did not try that. Thanks!
    #177 2 years ago
    Has anyone used these on the old Williams legs that were gold/brass coloured? I just got an IJ and would prefer to spend the rehab budget fixing the cab. Will the legs clean up or will evaporust kill the gold color too? I guess this goes for the wire forms as well
    #178 2 years ago
    Quoted from sohchx:
    Just did this on a set of frozen levelers on my Harlem Globetrotters; it worked great. I just used a little MAP gas torch, but propane probably would have worked.
    #179 2 years ago
    Some of the product videos show it not affecting decals and paint. I don't know if I'd be the first to try it though.
    #180 2 years ago
    Quoted from Cheddar:
    Has no effect on paint that I could tell.
    #181 2 years ago
    I used it on a gold set of legs for WCS 94 and they came out just fine. Ended up being a waste of time though because I got the legs plated a week later lol
    #182 2 years ago
    Quoted from sohchx:
    LOL. Well I'm going to try it - we'll see what I end up with! I can always put one in the back if it gets jacked up
    #183 2 years ago
    just did my 3rd set of standard chrome legs and I'm still amazed at how well this stuff works.
    6 months later
    #184 2 years ago
    So - Any concerns with saftey and Evaporust? I put my legs in my 4" tube with some heavy wire (any better ideas? seems better than reaching into the soup to pull them out) so I can pull them in and out easily, but what about the inevitable drips you leave behind? Just asking as I have two young kids and my work area is the garage, so I'm always extra cautious in areas they may be in and around.
    Also - Any recommendations for the 'basket' you can drop smaller parts in? I was thinking I could make something up with some mesh wire, but figured I'd ask here if there's something easier or able to be purchased without kludgy creation.
    #185 2 years ago
    Quoted from statictrance:
    I just use a pyrex glass flat pan with lid for small stuff I bought at Target for like $10. Then I can keep it from evaporating, and it's easy clean out.
    #186 2 years ago
    Quoted from flynnibus:
    I like that idea - but I was hoping to buy/construct something I could easily lower into my legs tube. I'm always tinkering my machines, but I'm not always doing a full blown resto (depends on what I get in, state of the machine, etc etc) so I'd hate to have a 2nd container just sitting around. If I could double my usage out of the legs tube by lowering something into it - that would be ideal.
    #188 2 years ago
    Unless you find a tube with small mesh... you're gonna be stuck. You might just try making something out of a roll of mesh material and molding into a deep tube that is open on one end.
    I use the evoprust on more hardware and brackets than legs. Legs are easy enough to just buy and walk away... the brackets, hardware, wires, etc etc are a much more tangled mess of sourcing.. so I find it more practical to rust remove and tumble stuff in that category.
    #189 2 years ago
    Want cheap? Drill small holes in an old plastic peanut butter jar with a lid and lower it into your tube with a wire handle/retriever.
    #190 2 years ago
    27 hours in the drink. Too easy.
    IMG_20180717_125921775 (resized).jpgIMG_20180718_170134244_HDR (resized).jpg
    #191 2 years ago
    I use a small mesh stuff sack for small parts and lower into the tube, affixed to a stiff wire for retrieval. I like flynnibus' idea for bigger things though.
    #192 2 years ago
    Hey jeffc....that tube I'm using look familiar?
    2 months later
    #193 1 year ago
    picked up two gallons this week at Pep Boys, reg price there is 19.99 a gallon, using a 25% off first time on-line purchase (on entire purchase) dropped it down to 14.99 per gallon
    able to purchase on-line and pick up in store avoiding a shipping charge so my out the door total with tax was around 32.68 which is a hella good deal on this awesome shit
    3 weeks later
    #194 1 year ago
    Any suggestions on temperature? I had an old fish tank setup so I have a small pump circulating the water and a little heater currently set to about 150 degrees, figured it would speed up the process.
    Any suggestions, might that be too hot?
    As for buffing, I was just using steel wool, what’s a better option?
    2 months later
    #195 1 year ago
    Love this stuff! About 3 hours in the tank and a lite scrub with steel wool. Good to go. Top was same as coin door
    #196 1 year ago
    ALL HAIL - EVAPORUST IS THA' TROOTH!
    #197 1 year ago
    What to do with these sad legs with paint on top of rust? I'm eager to join the cult, but what other miracle product should I use to remove the paint first? A stiff wire brush has been ok but labor intensive.
    #198 1 year ago
    Quoted from sandman74:
    Jasco paint stripper
    #199 1 year ago
    [quoted image][quoted image]
    Far Out, man! Evaporust is Out of Sight!
    (see what i did there?)
    #200 1 year ago
    Just use rubber gloves, eye protection, & proper ventilation when using the stuff. I use it for stripping cabinets - works great & no worries about sanding that lead based paint.
    Brush it on, let it sit for a while, & use course steel wool to remove paint, then rinse with water & Evaporust away.
    $ 76.95
    $ 34.95
    Playfield - Plastics
    Hookedonpinball.com
    Cabinet Parts
    Ramp-O-Matic
    $ 4.49
    $ 9.00
    Cabinet Parts
    Third Coast Pinball
    $ 199.99
    Medisinyl Mods
    PinBoss Mods
    $ 25.99
    Lee's Parts
    $ 86.95
    $ 369.00
    $ 7,499.00
    Nitro Pinball USA
    $ 48.00
    $ 9.95
    $ 38.00
    $ 48.00
    $ 4.49
    Filament Printing
    $ 29.95
    $ 209.99
    $ 94.95
