Hello again, i made a post long a go about my Cue-T by williams, i couldnt revive it so i make a new post. I have almost read every topic in the EM section to get it in working condition, so far i have fixed the step up / step down unit, cleaned all the score reels, fixed the advance unit, bypassed the coindoor with a start switch since the wire harness was all cut up, fixed the bumpers, cleaning in general and fixing some leafswitches. I belive everything (almost) works now except that the 10 score relay is stuck closed, what i have read and figured out is that a switch is closed all the time, i have checked all the 10 points switches and all are open, well atleast the switches is know for sure goes to the relay. When i coin up:
Score motor runs, resetting all the score reels to 0, even the 10 points one, then the stepper unit goes to 5 balls,
kicks out the ball and *bam* 10 score relay closes, and than ofc the score reel gets all wierd and the chime coil.
When i gameover the coil lets go, coin up and it closes again.
I desoldered the 10 relay and the game is fully playable, if i push the relay by hand the 10 point goes up, so there must be some switch that i missed, i got myseld a wiring diagram from some guy in australia who was kind enough to send me a PDF, im not so good at reading a pinball schematics so my hope is to post for help here.
What i have found is that the bumpers and the 4 "bumperslookalike" at the top gives 10 points none looks stuck, is the something at the score motor?
