Greetings everyone! This is my first post on Pinside, so I'm hoping to learn from all you experts and maybe contribute some of the little bits I've been learning.
I recently bought a Gottlieb Cue Ball Wizard that supposedly needed nothing but in reality had a number of issues. So far I've fixed everything except one problem that I think is beyond my skill set. The Wizard has a oscillating upper level that uses a solenoid to fire a full size pool ball at different targets. The problem is the ball kicker solenoid stays activated. When I got the pin, the solenoid was fried and the fuse was blown so I replaced them both. That was when I found out the solenoid remains locked down so I've now disconnected it.
This solenoid is fired from an optical switch that the ball passes through. I'm sure this switch is working because it still triggers specific voice responses.
So, any ideas where I should start? What causes an optically switched solenoid to stay locked down? By the way, I do have a manual for this machine but I'm not much good at understanding a schematic. Any help would be greatly appreciated!
