Started noticing ghosting (LEDs on when not supposed to be) in Taxi shortly after I changed the lamps to CT supers with the controlled lamp kit. To make a long story short, could not be singled out to any particular row or column. In single lamp test mode, One LED on might light one, two or three LEDs elsewhere at a very low level. I tried a few fixes, including soldering a 470 ohm resistor in parallel with the LEDs like done with the Ballys. No resolution.
I noticed today the same thing also with High Speed, it's just not as noticeable as Taxi. However, F14 Tomcat that I populated with Cointaker premiums is perfect. Not a single ghosting issue noted when I step through single lamp test mode.
I settled on a solution of removing the LEDs from Taxi controlled lamps and returning them back to standard incandescent lamps. Not too happy about it - but I'll live with it for now. From now on, I will only use the premiums LEDs in the controlled inserts on System 11 games. Just let this be a warning of the possible problems you can run into if you are a Sys 11 owner.
