(Topic ID: 138292)
CSI trough issue
By swampfire
6 years ago
  • 22 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by northvibe
#1 6 years ago
My CSI has been dogged by a very intermittent trough issue since I bought it, and I finally figured out the problem (but not the solution). Sometimes when I lock a ball in the Skull, the 3 balls still in the trough get into this configuration:
When this happens, trough switches #2 and #3 don't register - because the balls are just beyond the physical switches. Ball 1 registers at the "Trough Jam" switch, but apparently the software doesn't act on this. The game does 2 ball searches, goes to "end of ball", and only then pops ball #1 into the plunger lane. This makes it unfit for league play, of course.
I caught the game "in the act" today when this happened - as soon as it went into a ball search following the skull lock, I opened the coin door and went into switch diags. Only the "Trough Jam" switch was registering.
Since this is a mechanical problem, I assume there can only be a mechanical solution. I don't see anything about the trough mech that looks "wrong". Any advice would be appreciated.
#2 6 years ago
So the scoop coming out is boxed, see if one of the corners cracked. My tron and lwjp were doing this. Had to zip tie the scroop together. I can get pics if you need, but just look down from the top, you should see a crack if that is the issue, at least it is the first thing to try. Mine both were cracked in the upper side near the front.
#3 6 years ago
Yes, the scoop is cracked on both sides:
I also reproduced the ball position with the scoop removed (sorry for the poor focus):
I think what's happening is that the balls and/or the trough have become magnetized. I thought I installed carbon steel balls, but maybe I missed the one magnet in the game. I'll try carbon steel balls and see if I can reproduce the failure mode manually.
How did you zip-tie your scoop to repair it?
#4 6 years ago
BTW, thanks, fellow Duluthian!
#5 6 years ago
I used several layers of foil tape to shore up the scoop, and added a layer of mylar to the trough. I'll reply if that didn't fix the issue.
#6 6 years ago
If the tape holds it should. My tron is still working. I'll go take a pic.
#7 6 years ago
I had CSI years ago. Seemed like the worst ones for the trough switches. Changed out a few. Also had VUK switch fail.
#8 6 years ago
I never had an issue with mine except a wire fell off a coil lug...
Here is mine with a zip tie
#9 6 years ago
Dark enough? Geez
#10 6 years ago
Quoted from northvibe:
Dark enough? Geez
I can see it - thanks for the pic!
#11 6 years ago
The pinballs are not being registered properly by the opto transmitter
#12 6 years ago
Quoted from Cycloneman:
The switches and optos are working fine. The problem is that the game software ignores the "trough jam" switch when it does a ball search. The fix is to avoid trough jams (until I can rewrite the code with a P-ROC).
#13 6 years ago
Quoted from swampfire:
Welcome! I bet it is hotter there though
I asked this same Q earlier this year. Llyod answered and you can either buy a replacement scoop, zip tie, or have a local place (or you) weld it back), but this is a very common issue.
#14 6 years ago
Bummer - the problem is still happening (but less frequently). We used CSI in league play Saturday, and it happened twice.
#15 6 years ago
Did you ever try the zip tie instead of tape?
#16 6 years ago
I'll try both tonight. Belt and suspenders.
#17 6 years ago
Tron
#18 6 years ago
So tonight, I finally caught the culprit red-handed! I'm certain now that the remaining problem (much more intermittent) is that either the trough or the balls have become magnetized. Two failure modes, both mechanical in nature - and probably due to not using carbon-core balls.
#19 6 years ago
AHHHHHHH. My lwjp did some goofy crap int he trough as well as that game has 2 magnets. Good catch, changing balls out is always a good trick for a magnet game. Hope that is the fix!
#20 6 years ago
I just ordered new carbon-core balls for all of my Sterns. It was about time to replace them anyway.
#21 6 years ago
I just proved to myself that magnetized balls were my entire problem. I removed the trough and took it to my desk. Then I used a level to hold it at a 1 degree angle. The balls stuck to the wall! Then I redid the "experiment" with balls that I knew were carbon core. They moved freely.
I really feel dumb for putting Chrome Steel balls in this game - I'm usually more careful about that. Just glad that the issue is resolved!
#22 6 years ago
Man, those must of been magnetized good! Thanks for posting up an update!
