(Topic ID: 230869)
CSI blowing F10 fuse
By Gunnut40
  • 11 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by Gunnut40
#1 3 years ago
Hello pinside. I turn on my machine and it blows f10 fuse instantly. I have researched the problem here and this what I did. I unplugged all the connectors from power supply board(not the molex). The fuse still blew instantly. LTG says that this a bad bridge. I traced F10 to the bottom right bridge with a heatsink. I plan ordering a new one from macros and replacing it.
If y'all have any advice or any words of wisdom that would be great.
#2 3 years ago
Quoted from Gunnut40:
I'd pull the board and put a meter on the suspect bridge rectifier, if shorted you know for sure.
#3 3 years ago
Quoted from LTG:
Oh yeah testing...oops. I tested all of them for some odd reason 3 of the five were bad. I wonder why more fuses where not blown? This what I plan on ordering.
#4 2 years ago
You were testing them in circuit. I'd just replace the dead shorted one.
#5 2 years ago
Do you need the spade lug ones like in your picture, or wire lead ones ?
#6 2 years ago
Quoted from LTG:
It seems the correct rectifier with spades, and I'm quite sure that it is not the bottom right with heatsink but the rectifier just below F9 and F10.
#7 2 years ago
Quoted from LTG:
You are correct. Apparently testing boards at 3:00 in morning is no good. Just retested all good but one.
#8 2 years ago
Quoted from LTG:
Not sure I'll desoder before I order.
#9 2 years ago
Quoted from zaza:
Yep I was wrong. I'm not sure how I got so far off following a trace.
#10 2 years ago
Grrrr.... replaced the bridge but I pulled up some non trace removing the bridge. Now I'm not blowing a fuse or getting any power to the 20v. Any ideas or do I have to order a new board?
3 weeks later
#11 2 years ago
Issue resolved...I bought another board from K's arcade. I checked for any dead shorts/bad coils before installing. The original board did have other issues....centrifuge lock gate would not stay up and the GI's. would not go out at the start of mutiball. Yeah I fucked that board up....practice on old boards do it first for the love of God!!!!!
