Hi,
I have problems to crimp wires into .062 pins. I do not know if it is the tool, but most of the time, when I insert the crimped pin into the housings hole, it does not make a "clic", it does not stop and the pin is not blocked in the housing. It goes further and is loose ...
I know that there are 2 "wings" which prevent from removing the wire, but which part of the pin makes it blocked on the other side, i.e. prevents it to go too far in the housing ?
Can someone advise me please ? Thank you in advance
