Friends, Need some advice on a Creech I found. A little background - seller is a non pinsider and a former operator. Had game in his home for some time. Advertised as "in great shape, but having an issue with ball trough switch". Obviously upon my arrival I learned there are several other issues. Some details
- Game powers up.
- DMD looks crisp and clear.
- When start button is hit, the game doesnt recognize balls in trough.
- In switch edge test, several switches didnt register (slingshots, shooter lane, a couple roll over lanes, flipper buttons dont fire).
- In solonoid test, you can fire the flippers and EOS, and pops.
- Motor for hologram worked, but the "projector" that creates the Creech image did not work.
- Sound test registered good,
- Playfield looked pretty good, but i have included pics, is this planking in the pic?
- Inserts did not show a ton of wear, did not feel raised to the touch
- Scoop hole had pretty significant wear, is this normal or worse than average?
- Lamps and flashers all worked in test
- Cabinet decent, minimal wear, except near the flipper buttons. Pretty bad there (see pic)
- Most importantly - appears to have some green fuzz on those diodes right below those leaky batteries.
What would you pay for this machine?
I have a good amount of experience with mechanical issues, but still have not done board work. I assume the battery damage would be best dealt with by sending out to an expert?
Thanks for any advice.
