First post in a long time, been fortunate to be problem free since I acquired this Creature 2 years ago.
Went to fire up a game last week, and after pressing start, balls wouldn't feed into the trough lane. Finally got a chance to run tests, when I go into test mode, under solenoids, on "trough 4", nothing is happening.
New to this type of repair. I'm assuming the coil has gone bad, correct? I just lifted the play field (as I had lifted the field since it last worked), all connectors to the coil look good.
I assume the test would be to take a voltmeter to the coil connectors and see if it's getting volts under the test? If the coil is bad, it appears that I just need to replace with this part (http://www.pinballlife.com/index.php?p=product&id=159), correct?
Thanks for any help/advice. Like I mentioned, new to this type of repair. Not intimidated with doing my own repairs, just new to it.
