(Topic ID: 275710)
Creating playfield plastics, now done!
By Andrew96
  • 23 posts
  • 8 Pinsiders participating
  • Latest reply 1 year ago by J-roc
  • Topic is favorited by 7 Pinsiders
    #1 3 years ago
    Hi
    I found this post on recreating plastics which I found very interesting!
    https://pinside.com/pinball/forum/topic/how-i-recreate-plastics
    I do see it is 6 years old! But I have some questions hopefully someone may be able to answer
    So I have scanned my plastics in and saved them as a lossless TIFF format
    I have used the pen tool to create shapes round the plastics
    I then read "Using the Pen tool, I start out by creating outlines of the plastics and removing anything from the image outside of the plastics themselves. This includes removing anything between the printed artwork and the edges of the plastic."
    that I am at a loss at! I have managed to create a layer round the plastics, but I cannot find how to do this between the outside of the plastics and the image!
    Now I have removed the background outside the plastics the handles for the vector shapes have now disappeared!
    Also I have no idea what format to now save this work in to keep the transparency AND the vector settings!
    Any help would be very much appreciated, I have a graphics place that will be able to print these if I can get them done, but am struggling with photoshop!
    Many thanks in advance
    Andrew
    pla pin (resized).jpgpla pin (resized).jpgbgnd (resized).jpgbgnd (resized).jpg
    #2 3 years ago
    Simply save it as a Photoshop file.
    However, Illustrator is a vector tool. Photoshop is a raster tool.
    If you're going for vector graphics and intend to trace everything, Photoshop isn't quite the right tool for that.
    #3 3 years ago
    Many thanks, The article did say photoshop was fine with the vector side, realistically then I don't stand a chance of reproducing these
    #4 3 years ago
    Many thanks so here is the update, I managed to get a copy of illustrator CS5, been quite a learning curve!! I found when you wanted to do something there was always some step you had to do before it! I can see why there is no tutorial on how to use illustrator for pin plastics it really is not easy to explain!!
    47EE9AA1-FF96-494F-AF4B-EA684117CCA4 (resized).jpeg47EE9AA1-FF96-494F-AF4B-EA684117CCA4 (resized).jpeg
    That’s one original gottlieb 4 square plastic with the “ replacement” someone decided was a good idea!
    So scanned it in and slowly used illustrator to create the black vector format for it.
    42E6D2D1-ED6C-4565-A5A2-C379B5272AC5 (resized).jpeg42E6D2D1-ED6C-4565-A5A2-C379B5272AC5 (resized).jpeg
    Created separate colour layers for the red, yellow and orange, and the base white layer to go on last, red shown below
    6A211C9A-6DF7-41A6-BEBF-1E77ED3E973B (resized).jpeg6A211C9A-6DF7-41A6-BEBF-1E77ED3E973B (resized).jpeg
    And finally all layers shown
    534F733F-8349-4F9F-A052-EE24C3CB8DB5 (resized).jpeg534F733F-8349-4F9F-A052-EE24C3CB8DB5 (resized).jpeg
    Very pleased with the outcome so far! Still got the drill holes to do but had to stop for tonight.
    Thankyou for the tip on using illustrator, certainly a good move switching to that even though the learning curve is high!!
    Cheers
    Andrew
    #5 3 years ago
    done and ready for the printers now
    original scan
    #6 3 years ago
    Nice! Let us know how the finished piece turns out.
    #7 3 years ago
    will do, took it to the printers this morning and the layers etc are just what they need, as far as I am aware they will be printing the black and colours onto clear vinyl then backing the white area with white vinyl then this will be stuck onto PETG sheet 1.5mm thick and cut out with the holes done too, that's how I understand it will be done, they are having to get the PETG so no idea on timescale for now
    #8 3 years ago
    Nice work!
    #9 3 years ago
    Well I thought I would have a go at the most complicated plastic I have on the machine, it’s got a crack on the top corner. It’s taken a lot of time but it’s turned out well and I am happy with how it looks on the pc
    Side by side
    D64DC489-1553-4B8B-8939-E1F6E545716F (resized).jpegD64DC489-1553-4B8B-8939-E1F6E545716F (resized).jpeg
    Black template
    8A498313-F07B-41A8-831E-0534C148947E (resized).jpeg8A498313-F07B-41A8-831E-0534C148947E (resized).jpeg
    Red
    083AE6DC-4C88-4180-AB3A-DA5CA28A4D7F (resized).jpeg083AE6DC-4C88-4180-AB3A-DA5CA28A4D7F (resized).jpeg
    Yellow
    E23A61E5-8112-4020-8732-C1317614F157 (resized).jpegE23A61E5-8112-4020-8732-C1317614F157 (resized).jpeg
    Orange
    08706F59-2916-453C-B726-E72360149DC3 (resized).jpeg08706F59-2916-453C-B726-E72360149DC3 (resized).jpeg
    And gottlieb white!
    8A400A7F-0F75-4C70-9F93-74AE1E9A94DA (resized).jpeg8A400A7F-0F75-4C70-9F93-74AE1E9A94DA (resized).jpeg
    #10 3 years ago
    Screenshot as better quality picture!
    #11 3 years ago
    The printers have got back to me with the quote.
    To print 4 of the small ones onto 1.5mm petg and cut them out using my file.... £50
    so I did not think that bad at all! the plan now as I have the second image done is to take that to them and hopefully slowly do the remaining images the same and get them all done at the same time
    #12 3 years ago
    Finally managed to do all the rest of the plastic pieces in Illustrator, nos 3, 4, 5, and 6, the files are now at the printers
    Hers are the finished re-created plastic pics
    #13 3 years ago
    nice work, those look great.
    #14 3 years ago
    On the printer! Test prints
    CAA4154C-D189-4BB6-BC83-4A1750EDD6E0 (resized).jpegCAA4154C-D189-4BB6-BC83-4A1750EDD6E0 (resized).jpeg
    #15 3 years ago
    2CE590D6-6B9D-492E-925E-6A4A7D9E13CA (resized).jpeg2CE590D6-6B9D-492E-925E-6A4A7D9E13CA (resized).jpeg
    #16 3 years ago
    Call from the printers so went and got the newly made plastics! All laser cut out too so nice and smooth edges!!!
    A29FE9DA-3983-4AA0-9D1D-163B0AA652DB (resized).jpegA29FE9DA-3983-4AA0-9D1D-163B0AA652DB (resized).jpeg
    34EAE014-9E80-4F3C-BB2E-EA19050464CE (resized).jpeg34EAE014-9E80-4F3C-BB2E-EA19050464CE (resized).jpeg
    D2C14959-537F-40E1-890C-2F32DE35B097 (resized).jpegD2C14959-537F-40E1-890C-2F32DE35B097 (resized).jpeg
    877F54B3-C707-4ACA-886F-22F3B621C4F0 (resized).jpeg877F54B3-C707-4ACA-886F-22F3B621C4F0 (resized).jpeg
    09B6CD0A-478E-4B49-B847-2C990C8D0CA7 (resized).jpeg09B6CD0A-478E-4B49-B847-2C990C8D0CA7 (resized).jpeg
    And they did the white layer on the back to diffuse the filament lamp under!
    85A106E0-CB0D-47A1-ACC1-5CA1D66CFAA1 (resized).jpeg85A106E0-CB0D-47A1-ACC1-5CA1D66CFAA1 (resized).jpeg
    #17 3 years ago
    I got them to print the whites as white so it all removes the yellowing if the plastic as much as possible! I think they have done a cracking job!!! Very pleased with them!!
    I did expect to see more of a difference in the old and new because of screen printing on the original and modern ink printing on the new ones, but I am well impressed how they have turned out!!! Very vibrant!!!!
    #18 3 years ago
    Laser cut from A3 sheet
    EAC5DE04-948E-479E-B7E8-C30EDA92E972 (resized).jpegEAC5DE04-948E-479E-B7E8-C30EDA92E972 (resized).jpeg
    #19 3 years ago
    Those look great!
    #20 3 years ago
    Damn, that's sweet.
    2 months later
    #21 3 years ago
    Glad I came across this post as I am working on a 4 Square right now that has a broken right sling plastic. I'd love to be able to get a new set for the entire playfield.
    4 weeks later
    #22 3 years ago
    Is there a specific scanner that should be used? The
    2 years later
    #23 1 year ago
    Andrew My 4 square plastics are all trashed, contact me
    This page was printed from https://pinside.com/pinball/forum/topic/creating-playfield-plastics-in-photoshop-cs2-questions and we tried optimising it for printing. Some page elements may have been deliberately hidden.
