bram stokers dracula. In switch test with all connectors removed from the bottom of the cpu board. Using jumpers and diodes, if I activate any switch in row 1 and any switch in column 1 at the same time, I get those two switches plus the corresponding "battleship" switch. I mean if I use the 3rd switch in each I get the 3rd in and 3rd down on the matrix. First problem was a ground short and I have replaced U14, U20, and U18. Now this crazy stuff
Each switch will work properly if activated separately, and only combos of row 1 and column 1 cause the third switch register. None of the other rows or columns will cause this to happen. Any ideas?
