(Topic ID: 47037)
Crazy Stuck Balls
By wxforecaster
6 years ago
  • 33 posts
  • 23 Pinsiders participating
  • Latest reply 5 years ago by Nilroc
There have been 26 images uploaded to this topic. (View topic image gallery).
#1 6 years ago
Wow, I can't tell you how many hundreds of games of TAF and FH I've played over the years each, and to have both of these occur in the same day should be a lotto play. Furthermore, both of them ended up as recent personal best scores -- including a 295M first ball on the attached TAF and 36.6M on FH.
TAF yielded a very rare "Dirty Pool Old Man, I Like It" when the ball finally shook free (balanced between the two screws on top of the bookcase.
#2 6 years ago
I thought this was an announcement of a new title !
#3 6 years ago
Had this one a while back on my LAH. Only happened once in the 11 years I've owned it.
#4 6 years ago
Here are a couple.
#5 6 years ago
1 month later
#6 6 years ago
#7 6 years ago
Join stucky balls group on facebook to see tons more...
Here's a recent one of mine. The flippers actually stopped working, ball saver post stuck up and the game just stopped like this. Couldn't figure it out at first, then noticed the coin door had popped open just enough to disable high power...closed it and continued to play..
#8 6 years ago
Nice pics guys.....nice games you put up there wx
#9 6 years ago
This one happened to a friend at my house on Saturday, he has a FH too and said he's never seen that before. Happened during multiball, so it worked out good for him to rack up some points.
#10 6 years ago
Just had a ball stuck on TFTC. The ball took a hop and got stuck on the edge of the right ramp and wedged between wire forms. It stuck hard enough I had to take the glass off and tug it out.
#11 6 years ago
i didnt find back the 2 balls blocked on the top of the basket on the (stern) NBA
and
#12 6 years ago
these little buggers find some weird places
#13 6 years ago
Quoted from Vyzer2:
wow...the apron rails should have prevented this
#14 6 years ago
Quoted from wizzardz:
Worst was, It happened while a had my highest game going.
#15 6 years ago
I heard that type of jam is a pain in the neck to get out too, if you don't watch it you'll end up busting your playfield glass.
#16 6 years ago
Dirty Harry Stucky Balls - get your minds outta the gutter!
#17 6 years ago
Never had one stuck there. It looks like you have some vertical piece holding it in. On mine have have the ramp lip that lies relatively flat there
#18 6 years ago
This ball is stuck between the ramp cover and the glass very tight fit and it was hard to remove the glass lol
#19 6 years ago
This ball is stuck between the ramp cover and the glass on my acdc very tight fit and it was hard to remove the glass lol
#21 6 years ago
stucky on my big brave.
#22 6 years ago
Quoted from Gorgar1:
wow
#23 6 years ago
Gophers!
#24 6 years ago
on that precise pinball, its quite a normal thing...
1 month later
#25 6 years ago
Managed to capture this one behind the King Pin drop targets. Hit the last drop target and then hit the ball back at the bank about the time the targets reset. Glad it didn't break a plastic or target
#26 6 years ago
I had exactly the same stuck ball as Gorgar ... On ACDC.
#27 6 years ago
Coffin/Sparky stack, this has happened 3 or 4 times since then...
#28 6 years ago
I knew I should have taken pics of it.
So this week I had a lot of these.
NGG under the golf cart over the putter hole had 3 get up there somehow in 1 ball.
A buddy was playing RBION and was in multiball. Had 3 balls stick 1 in the left inlane, 1 on top of that coming out of the wireform from left ramp. And another behind that coming from the right ramp wireform back to left flipper. All perfectly stacked and could not be wiggled out. pulled off glass.
A couple of years ago had my old TFTC on location and a ball was stuck on top of the 180deg ramp wireform. Similar to the BK2K pic above.
Good stuff guys thanks for sharing
#29 6 years ago
Got a neat stuck ball the other day. Perfect timing during multi ball caused a collision as a ball ejected from the scoop resulting in this. Dislodged as soon as the ball came out of the scoop.
#30 6 years ago
Stuck ball on WOZ - hopped the rail from the castle mini playfield when the witch was up and got lodged between the castle playfield and the witch
1 month later
#31 6 years ago
Got every single ball stuck in the Parlay hole on POTC the other day, fun!
1 month later
#32 5 years ago
Couple stuck balls on Junk Yard. The first was a pretty spectacular airball that lodged on the far left ramp. The second is a place that I've gotten stuck a couple of times, really jammed in there and impossible to remove from the front.
#33 5 years ago
