(Topic ID: 271426)
Crazy slingshot
By Burton
20 days ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 11 days ago by Burton
    #1 20 days ago
    I have a sling shot that gos off on its own multiple time during game play on my lethal weapon 3. How do you go about fixing this problem???????
    #2 20 days ago
    Your switches might be overly sensitive, I've seen this on several machines. A slight nudge will trigger them.
    #3 20 days ago
    Power off, adjust contact gaps on slingshot. When it kicks well and does not machine-gun, the gaps are right.
    Don C
    #4 19 days ago
    Rubber ring maybe to tight.
    #5 19 days ago
    Turn the game off. Remove the plastic over the sling shot kicker and leaf blade switches. Pull on the rubber ring around the posts, so you have equal pressure on all sides, not tight on the kicker/leaf blade switch side. The leaf blade switches - front long one should be resting on the rubber ring, not pushing it or away from it. Shorter rear one should be close enough so the slightest ball hit triggers it, yet vibration doesn't. There are two leaf blade switches, one each side of the kicker. At least one needs a little adjusting. When bending forward or backward, get as close to the fiberboard spacers as you can.
    #6 11 days ago
    Thank you very much. That fixed the problem !!!
    $ 229.99
    $ 99.99
    $ 18.00
    The MOD Couple
    Various Other Swag
    Third Coast Pinball
    $ 3.50
    Pinball Mod Co.
    Iron Monger Decal Out of stock
    Flashinstinct
    £ 99.00
    PinballToys
    Back Alley Creations
    $ 78.00
    Creo Pinball
    $ 149.00
    $ 125.00
    $ 29.25
    The MOD Couple
    $ 38.50
    The MOD Couple
    $ 7,999.00
    Little Shop Of Games
    $ 32.00
    CzTV Mods
    The MOD Couple
    $ 22.50
