I am cracking green targets on A F M. any suggestions to prevent this? Is this common?
mylar. Decals. more backing?
If you keep your game clean, waxed, new balls.
Then you are doing better than what the game was designed for.
Try going one flipper coil weaker.
You have the strongest William coil in your game now -
FL-11629 (blue)
The next one weaker is -
FL-15411 (orange)
You'll still make all your shots and your targets will last longer.
LTG
Quoted from LTG:Try going one flipper coil weaker.
I did this on my AFM, and I'm glad I did. There's much fewer airballs, less impact on targets, and the game still has plenty of flipper power and plays plenty fast.
Quoted from Av8:MIne are brand new green targets. Great idea above.
Whos decals?
I usually get them from Curly.
hmmm good thread. I'm yet to restore mine, but bought all new targets. I'm not a big fan of target decals, but in this case, I may do it.
Quoted from Atomicboy:I'm not a big fan of target decals, but in this case, I may do it
You will change your mind after you break a couple of those brand new targets
I also put weaker coils in the game I had and I had no problems hitting all the shots, including the ramps, with ease.... and everything wasn't getting bashed like crazy like it was with the stock coils.
Well there was no target foam behind any of the new targets. Shattered the top left one today.
Ill order some faom and will give that a try. May try weaker coil if they break, strip the screws out or bend back.
Quoted from Av8:Ill order some foam
It is only foam weather stripping that you get for $3 a roll at any hardware store. Get the self adhesive stuff.
This is off pinball life web sight.
It is not recommended that you "tinker" with the balance of flipper power supplied by the original flipper coils. But if you must tempt fate, here is a list of coil numbers and their relative strength going from weakest to strongest:
FL-11753 - Used with short flippers and close shots
FL-11722 - Used for close shots near drop targets
FL-11630 - The standard, most commonly used coil
FL-15411 - Used for long playfield shots
FL-11629 - Used for long shots and high ramps
Im going to try 15411. Thanks.
The target faces may be cracking if the rivets were done incorrectly. BAA was selling just the target faces so easily replaceable. I used my old ones, just flamed pushed the face of the target.
Quoted from Av8:It is not recommended that you "tinker" with the balance of flipper power supplied by the original flipper coils.
You have to remember though Williams over powered flippers because they knew street maintenance was slipping and games needed more power to work on dirty games.
Now a person taking care to clean, wax, new balls, and keeping the flippers in great shape can easily go one coil weaker and make the same shots and not break as much stuff as fast.
LTG
Target decals are great. Also, the backing tracelifter incorporates into his targets looks like a very good idea...
Quoted from tracelifter:I made backers for my targets so they don't bend back, you can see one in this pic on the right.
I have extras in stock and just replace them when they break.
Make sure the foam behind them is in place.
Could you possibly upload another couple of pictures from another angle? I hope I'm not going blind but I honestly can't see where the foam/backer is.
Concerned about targets breaking, and being in England, it's not easy to get ready made target decals.
Quoted from dragon2000:Could you possibly upload another couple of pictures from another angle? I hope I'm not going blind but I honestly can't see where the foam/backer is.
See the green plastic face of the target ? See the metal upright support piece behind the green plastic target that the target is fastened too ? The foam backer attaches to the metal piece between the metal and back of target face.
LTG
Look at the pic, see how the red target on the right is parallel to the black line? Now look at the green target on the right in front of it, see the metal L brace I made behind it screwed to the top of the PF?
This supports the target so it can't bend back and pull the screws out underneath.
Now look at the left, that side doesn't have one yet and the red target is crooked, I hadn't done that side yet.
The foam is black hi impact and is between the back of the plastic target leaf and the steel target rod.
Quoted from Av8:Check out the flipper bushing
Regularly check the left flipper. It gets a direct ball hit from the kick out and that bushing takes a beating.
LTG
This page was printed from https://pinside.com/pinball/forum/topic/cracking-targets-afm and we tried optimising it for printing. Some page elements may have been deliberately hidden.
