CPR Bally Star Trek Playfield Mod.............
The New CPR Bally Star Trek Playfield comes complete with this New Custom Mod Kit ready to install during your Playfield Swap ( No additional charge for the mod ). This is version 3 Revision and is shot as a Mock-Up and Triggered Manually. In "Ready Mode" the Enterprise Engine Nacelles will have a Low "glow" and during game-play making the Warp Factor Shot will trigger the Mod Sequencing......Again, this is just a Mock-Up....
What you see on the playfield in this video is a foam-core section of the new PF graphics that I did for the new playfield. I cut 2 holes in the foam-core and inserted real Clear Plastic Inserts and then covered the foam-core with an ink-jet print and mounted the actual Mod to the backside behind the clear inserts. This mock-up was created so that we could test the programming for proper Switching and Sequencing. The mod is hooked up Temporarily which is why you will see wires on the playfield and for this video I had to trigger everything Manually, so it's a bit "off" from the actual game-play trigger but you will get the idea.
Our new CPR ST Mod will ONLY be usable in the New CPR Bally Star Trek Playfield and will Not work in an original Bally PF. Our new PF is custom designed specifically for this mod. For the "purists" out there that will not want to install this mod you have nothing to worry about as the inserts are covered with screen-printed graphics and the inserts will not be visible if you do not install the mod.
We are only making enough of these mods to be shipped with our new playfield and they will Not be available for purchase separately, so please don't ask to buy one as there won't be any available to buy.
I developed this mod to be an "Earned" Mod, so to activate it you have to "earn it" by shooting the ball into the Warp Factor ( upper right pf shot ) thus rolling over the Shooter Lane switch which activates the end-of-ball Bonus and Collects the Value. The Warp Factor was the perfect switch for triggering the Engines on the Enterprise! There are actually 2 New Switches with this mod so that the shooter lane switch keeps in sequence with the ball-in-play (first activation sets the mod in "ready" mode & the second activation "triggers" the mod. The second switch actually turns off the "ready mode" in case you never make the Warp Shot during ball play; this keeps the program sequencing correct throughout the game ).
Installation will be very simple during your PF Swap and should only take about 7-8 minutes ( all new Hardware is Included with the Kit ).
Stu
CPR Art Director
