Hi all,
I know this has been discussed before, but without clear resolution.
CPR does not offer a trim kit to cover the 3/8" un-painted edges of the reproduction backglasses that they sell.
The backglasses are beautiful ! Really nice work, but edge treatment is desperately needed.
I have numerous sets of translite trim for standard translite glass.
I have never had trouble installling trim and a translite.
None of the standard trims fit correctly on this glass. It seems too thick for standard edge trim.
People have successfully installed top trim and lift channels, but always lay off the side trim and consider it impossible.
I have ordered system 11 trim from pinball life and it may be exactly what is needed even if a little friction tape is needed to secure it.
I also ordered wpc-95 trim.
Ill know more when it arrives.
The problem is the rib/ridge inside of standard trims to allow for a translite.
The rib/ridge is not needed in this application.
I have 3 of these backglasses that will be installed at some point.
What is the correct trim to install that will cover the edges and eliminate the light bleed that ensues?
