Pascal's PCBs have a circuit that protects against shorted coils, shuts down power to the coils.
jojo, so you are saying coil 8 worked fine with the original gottlieb board set, CPU, Driver and power supply? And then you installed the all in one and now coil 8 doesn't work? You did nothing else, just installed the all in one?
Quoted from jojo22:well the thing is, my buddy had a pascal board, and the same thing happened. His board works in his joker poker.
Don't understand "the same thing happened". Are you saying your friend had the same coil 8 message in his JP as you have in your Genie?
Did you try your board in his JP and vice versa?
Well if coil 8 worked with original boards and then all you did was install pascal's board coil 8 should work unless something is wrong with the board!
Have you looked at your connectors contacts for corrosion? System 1 is notorious for contact and connector issues,
Have you checked the connector and contact that drives coil 8?
I have a Genie. I'll look up where coil 8 drive is coming from and then you can check contacts.
