I've attached some hi res photos. I have the board with me today at work with my DMM and my Nikkon camera so I can test connections and take photos of requested spots if needed. So far on this board,
I've replaced the following:
C1
C12
R192
C30
C11
C5
C7
C6
C8
C2
BR1
BR2
BR3
BR4
BR5
J114
J115
J121
J101
J102
LM323K
It also looks like some work was done on this machine before I got it, these look like these have had some solder work done on the joints
Q40
Q42
On the J Connections I also replaced the connections on the wires, when I got the machine, they were either burnt or britel. Ill attach photos of these as well, I checked them numerous times and they look right to me, but if someone see's a issue let me know.
(the J connectors/crimping was done a week or 2 after i got the machine, and haven't had a issue, I bring it up now, since removing the board numerous times, a couple of the wires where 2 were crimped into 1 hole had come out. im 99.99% sure I have put them back in the same place. later they had fallen out again, (crimping 2 in 1 hole isn't a great secure crimp) so I soldered the wires together and crimped them again, sorry for the lousy work on the yellow wire connector, it was a hard angle to reach in this instance, I plan on re-doing them when I get the machine up and running again).
I'm a bit curious on C1 and C12, I ordered CCA-0.001uF-50V from GPE, they look like they matched the original, but they physically look different. can someone tell me if they are okay or wrong?
