(Topic ID: 314442)
Corvette resetting
By pindude80
2 years ago
  • 16 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by pindude80
#1 2 years ago
I went to play my Corvette after not playing it for a few months. Everything seemed good and then when I was in a multi-ball it reset. I started a new game and hit both flipper buttons rapidly and it reset again.
I hooked up my DMM to test point 2 on the power driver board and it was at 5.2 volts in attract mode. I left it hooked up and started playing a game and it held steady at 5.2 volts. It reset and I looked up at the DMM and it was still at 5.2.
Any ideas on what I should look at to see what is causing the reset?
#2 2 years ago
Usually a driver board issue. Swap it with a working driver board to confirm that’s the issue and then repair the driver board.
#3 2 years ago
Connect to + side of C31 on the MPU board and monitor the 5volts there. You can be losing voltage between the J114 or J210 connectors.
So with good J114 and J210 connectors, you should only lose about .03 volts by the time it gets to C31+ on the MPU.
#4 2 years ago
Congratulations! You have discovered the most common problem with 90's Williams/Bally pinballs!
There is a bit of a journey towards getting this fixed, so I recommend you read the entire section about WPC resets on the pinwiki:
https://www.pinwiki.com/wiki/index.php/Williams_WPC#Game_resets
Keep us aware of your progress!
#5 2 years ago
More than likely a connector issue. The link above will discuss which ones to check
#6 2 years ago
I hooked my DMM up to the positive side of c-31 on the mpu board. In attract mode and casual play it held pretty steady at 5.18 volts. If I hammered on the flippers I saw it dropped to 5.14 volts.
I looked at the j114 and j210 connectors. A couple of the contacts in the middle of the j210 connector look slightly tarnished. I will probably go ahead and replace the connectors and housings on both j 214 and j210.
#7 2 years ago
Any tarnish on the red pins of J101?
#8 2 years ago
I had this issue when I was shopping out a Corvette. I went through a bunch of the usual WPC reset troubleshooting and couldn't sort it out. Voltages were good. Connectors looked really good too. Turned out to be too much on my circuit in the garage at the time. Standard 15A circuit with a GFCI. When a portable air conditioner or dehumidifier were running I would get reset issues usually during a multiball with lots of coils firing. Unplugged those and zero issues with the game. Its funny, the breaker or GFCI never tripped though.
#9 2 years ago
It's hard to see exactly, but it looks like your power in plug has corrosion/battery acid damage.
You've got a replacement CPU, so it wouldn't surprise me if someone plugged the battery acid compromised connector into a brand new CPU and thought that would work.
If you are seeing what I'm seeing, you'll need to replace that connector, with Trifurcons.
You need to get extremely good power to the CPU, any tarnish or corrosion anywhere on the power delivery plugs and connectors... you'll need to replace them.
#10 2 years ago
Quoted from DudeRegular:
I was thinking it may have been an issue with the line in power also but the funny thing is that it has been set up this way for years and it just started doing the resets.
I do have a dehumidifier in the basement but it is on the opposite side so I'm not sure it's on the same circuit but I may try to unplug it to see if it changes anything.
#11 2 years ago
Quoted from PinballManiac40:
I'm not sure I'll have to check.
#12 2 years ago
Quoted from PinRetail:
Which plug connector is the power in?
#13 2 years ago
From the other work that I have seen on this game prior to me getting it I wouldn't be surprised at all either if they thought the new board was all they needed to do.
Yep, I agree, whenever I replace connectors I always swap to trifurcon connectors.
Are there any other power connectors that I should look at and or change? If so, do you know which ones they are?
#14 2 years ago
J101, J114 and J210 would be the connectors that can cause reboot issues.
#15 2 years ago
I checked J114 and J210 per your advice. I'll also look at j101. Thanks!
2 months later
#16 2 years ago
I finally got back around to working on Corvette.
I replaced the connector and contacts for j210. I played a few games and everything acted normal. I hammered on the flippers with the DMM connected to the positive side of c-31 on the mpu board and I only saw it dropped to 5.18 from 5.20.
I'm not 100% sure that the reset was being caused by that connector. The reason I say that is because my Dirty Harry reset on me a couple weeks ago. When I first got the Dirty Harry it started resetting as soon as I brought it home. It was my very first game and I didn't know how to work on pinball machines so I had a local guy fix the board and it has not reset again until a couple weeks ago. When it reset I started digging. I looked at my line voltage and it was down to 116 volts. I like to have all of my games turned on at the same time. I hooked the DMM up to my surge protector that I have a few of the games plugged into and then I started turning the games off one by one. I picked up approximately 1 volt for every game I turn off. I think that was the cause of the Dirty Harry resetting and maybe part of Corvette resetting but I tried playing Corvette with all of the games on today and it eventually did reset but before I fixed the J210 connector it would reset as soon as I hit the flipper buttons.
So, lesson learned for me is to make sure to check line voltage first because we know low voltage will make the games reset.
Thanks to everyone for all of the diagnostic help!
$ 329.99
$ 24.95
Mitchell Lighting
5,800
Portland, OR
$ 44.99
Pinball Shark
$ 109.99
Etten-leur, NB
$ 9.95
$ 5.00
Mitchell Lighting
Nezzy's Pinball Prints
7,000 (Firm)
Kenosha, WI
$ 79.00
PinballReplacementParts
6,795
West Chicago, IL
$ 54.95
$ 22.50
bdash's bits
$ 37.50
