Hi,
Shooting the ball at the engine: If I understand properly, in normal mode (not ready for rev) , and provided the shot is strong enough, the ball should go thru a passive gate (1), then the engine entry gate (2) and finally the engine exit gate (3). In normal mode, gates 2 an 3 should be up.
When I launch a ball (from the ball shooter) in normal mode, gate 2 is up (open), and gate 3 goes up (opens). both gates are up, which looks normal. After a few seconds gate 3 goes down automatically and closes.
When shooting the ball at the engine, it is blocked by gate 3 which is down.
Is it a technical problem ? Could the problem come from the coil ?
thank you
