(Topic ID: 110634)
Corvette Club (members only but passengers allowed)
By Whysnow
5 years ago
  • 360 posts
  • 82 Pinsiders participating
  • Latest reply 6 days ago by Viggin900
  • Topic is favorited by 30 Pinsiders
There have been 122 images uploaded to this topic. (View topic image gallery).
There are 360 posts in this topic. You are on page 7 of 8.
#301 1 year ago
@ yuriijos : experimenting at the moment, if I find a good solution i'll post it. The lockbar can be adjusted with the (brass) screws on the lockbar receiver.
#302 1 year ago
@ yuriijos: after testing several stronger coils and positions, I ended up with the original coil but moved the bracket a few mm to the right (away from the switch). Mine was close to the switch , just touching it. Now the balls come out smootly.
#303 1 year ago
Quoted from yuriijos:
Still having issues with the LT5 kick out but only seems to get stuck when all three balls are locked and starting multiball. I tried angling the bracket a bit more so it’s kicks the ball more to the side instead of up and hitting the muffler plastic assembly, didn’t really help. Once the first ball gets free the others have no problem tho. If there is only one or two balls in the lock lane the kick out works but three balls and it jams up?
This was happening to mine too when I got it. From memory, there is a post that the muffler mounts to close to the lock kickout. I was having a ball pop out and hitting the bottom of the muffler and going back into the lock area. I needed to lift the muffler, but there isn't anything to bend, so I didn't think it was bent down either. The nearest mounting point to the kickout had a washer on top of the fastener. I put that washer under the bracket of the muffler and it lifted it up just enough that now there is no longer any contact when the ball is popped out of the kickout.
#304 1 year ago
Nice I’ll investigate both options above and see what happens. Your right tho, there is no play in that muffler assembly so I’ll try the washer to raise it a little and see if that helps. In order to move the bracket for that coil assembly isnt it best to just largen up the holes on the assembly so it has more play instead of screwing in new holes under the playfield? Thanks guys.
#305 1 year ago
I was very doubtful that just a washer width more height would do anything, but it literally fixed the issue for me. 75+% bouncing back in to 0%. I’m hoping it’s that simple for you.
#306 1 year ago
Why would it kick out balls just fine when there is only 1 or 2 balls in the lock but when there is 3 it gets stuck tho? It’s like the weight of the 3rd ball hinders the kickout so must mean the position or the bracket needs to be adjusted and not really the height of the muffler assembly. I’ll play with it more when I get time and report back.
#307 1 year ago
^^^^Anybody? Also wondering if there is a way to tighten or snug the lock bar assembly down when in the locked position as mine seems a little loose to the left and right. Thanks.
Make sure it is lined up properly and clean the popper plunger. Add a new sleeve also.
#308 1 year ago
hey guys, new to the corvette club, owned my machine for a few years now and i love it. ive added a few corvette matchbox cars over the years but most recently ive always felt the top of the engine is incomplete. i found a picture of the actual engine online and made a piece to sort of match it. let me know what ya think.
b522852bacc0c0f07cd417fde0518aec (resized).jpgIMG_2188 (resized).JPGIMG_2192 (resized).JPGIMG_2198 (resized).JPG
#309 1 year ago
I like it! Have an extra you want to sell? Just curious how you mounted the cars since the wheels spin and adding double sided tape to only the wheels wouldn’t be very secure.
#310 1 year ago
im planning on making a bunch of them to sell. hopefully i can do them this week sometime, ill let you know when they are ready.as for the cars i drilled and tapped screws into the bottoms of them and screwed through the acrylic plastic they sit on and the whole piece is screwed to the ramp. i wired up some headlights and tail lights too
#311 1 year ago
Still looking for a used set of ramps, particularly the left ramp!
#312 1 year ago
Hi everybody. I'm having some issues with my corvette pinball machine, particularly the LT5 engine. When I first fire it up the engine coils pull it and hold it to one side and the self test fails. If I do the self test from the settings it will pull to the left and eventually pull over to the right and the self test fails. I'm getting no number readings from either left or right sensor even when I manually move it. It had been working fine before, nothing was done to the machine. I've recently moved so it's been transported and hasn't been used for a few weeks but when I turned it on the other day I noticed this. I'm curious if something was bumped during transporting maybe? Any ideas what I should be looking for? Please let me know, I need to get it rumbling again. By far my favorite part of the game LOL. Thanks
#313 1 year ago
Quoted from Clizifer:
BTW I must say I absolutely love this piece! Wondering how I can get my hands on one for my machine. Please let me know clizifer thanks!
#314 1 year ago
Quoted from saulsilver:
thanks, i finally had a chance to make a few of these over the weekend. i have 10 available for anyone whos interested. shoot me a dm and we can work it out.
1 month later
#315 1 year ago
Hi guys
Is the right "Skid ramp" and the plastic engine block available anywhere ? Google couldn't help me.
Matt
#316 1 year ago
I recently acquired a Corvette unfortunately the pf is toast and there are a few hacks making it too expensive to bring back. In any case, I'm going to use the cab and some parts for another project and will be selling off the rest. A few parts may already be spoken for and I'm trying to put together pricing. PM me if there's something you're after.
3 weeks later
#317 11 months ago
Hi guys,
I have an issue with the lock sequence, when the ball goes to the engine, this one is shaked during the video sequence, then stops and then the ball get stocked inside...I have to wait for a ball research to open the gate to free the ball...it is the same for each ball locked. Gate does not seem to open to release the ball on time...however, optos, gate and engine are working properly, so I don't know what to check...if you have any ideas... thanks.
2 months later
#318 8 months ago
Hi Corvette owners. I’m thinking of joint the club. Can I get an idea of what is unobtainable? The left ramp on my example has been repaired but not well. Are there other parts I need to look out for?
1 month later
#319 6 months ago
Wow, 55 days ago I posted here and nobody since.
I’m going to try to post here again, does anyone have a spare speaker panel they would sell?
#320 6 months ago
Quoted from allsportdvd:
I think I saw one in the random market ads yesterday.
#321 6 months ago
Quoted from desertT1:
Link at all? I can’t find anything related to Corvette for sale
#322 6 months ago
Just found it. It was an LED kit that used the Corvette panel for reference, not selling the actual panel. Sorry about that.
#323 6 months ago
Damn, back to the drawing board. If anyone can help with a speaker panel let me know please
#324 6 months ago
Hi all,
First post but enthusiastic observer for a while now - if anyone knows of a good condition Corvette for sale in the UK, please let me know.
Big thanks
1 month later
#325 5 months ago
Hi all
Does anyone have a spare spinner decal or can point me in the right direction? What’s the 2nd side look like, I’ve only seen this side
#326 5 months ago
Hi all
Does anyone have a spare spinner decal or can point me in the right direction? What’s the 2nd side look like, I’ve only seen this side[quoted image]
the other side has a picture of a turbo on it. haven't seen any reproductions anywhere
#327 5 months ago
Hello ‘Vette owners. I’m rebuilding my corvette playfield after a shop out and I’ve lost my way a little bit, wondering if I can seek some help please. I can’t identify the post type that goes into the two holes behind the pit stop... as seen in this photo.... I know they will retain a rubber ring and that the rearmost one will protrude through the plastic to retain the habit rail support overhead.... but I can’t identify the actual part to use. Could someone please respond with a photo? Thank you.
Worked it out, no need to respond thanks.. 2 x metal posts.
#328 5 months ago
I am looking for spare parts for corvette pinball. Ramps, plastics DMD Bezel. Thanks in advance
#330 4 months ago
Can anyone help with the pavement of the spring onto the gate at the exit to the LT5 ramp? How is it supposed to attach?
Here is a pic of mine as it stands
#331 4 months ago
Looks like your spring is too long.
#332 4 months ago
Looks like you 2 plastic rings on your switch too, I only have 1.
#333 4 months ago
Quoted from PinballManiac40:
Do you happen to know the part number for that spring?
#334 4 months ago
No. I imagine it is listed in the manual.
Even now, you can shorten it up a bit. Just stretch it at least 1/4" on the end and hook it on. Then you should be able to manually pull back on the coil plunger arm to see if it pulls the gate open, If not, shorten the spring up some more.
#335 4 months ago
For reference that spring part number is 10-194 and is the correct spring for the rear gate.
Now I’m further along in the restoration and unsure where these clear plastics and metal plate go. Anyone know?
#336 4 months ago
Now I’m further along in the restoration and unsure where these clear plastics and metal plate go. Anyone know?[quoted image]
The metal part goes here to the end of the racetrack:
One of the triangular plastics goes here:
#337 4 months ago
Nice shop job on that Corvette! ^^^^
#338 4 months ago
#339 4 months ago
Yes, did that last weekend...
#340 4 months ago
Quoted from BigLebowski:
Thank you, I have since figured out those 2 pieces. Your Corvette looks sharp!
#341 3 months ago
Well after working on this machine since July I can happily say my Corvette is restored and playing nicely! Here are some pics of my job. New parts everywhere!
CD59E761-0756-48FF-86B9-F1469664259C (resized).jpeg01899504-4DDA-4F98-9568-88288DFBE0C9 (resized).jpeg33D44099-DBF3-4E44-B5CD-165D83094A49 (resized).jpeg15A8096F-7E99-4476-BD7E-64284E66A192 (resized).jpeg0B9F10A7-726A-4CF3-8555-A8A16D1463F4 (resized).jpegE61732AB-E37E-46DF-8353-BA570A57D358 (resized).jpegBE44BB12-5ABD-4D7D-8CBA-B9104E47120D (resized).jpeg
#342 3 months ago
looks great!! i like the led strips you have going up the dragway
#343 3 months ago
HI,
I need a fresh spinner decal as well as the back panel decal.
Does anyone know where I can find these ? If not, would anyone here be able to print it ?
Matt
#344 3 months ago
Quoted from Flippermatt:
HI,
Matt
I need both of those too, can't get them - good luck
#345 3 months ago
My ramp sign was missing the mount so I made a metal one a few years ago. Today I decided to make a legit one that looks like the highway overpass stuff. Need to clean up the 3D printed support stuff but it came out pretty well I think.
62A810B5-0578-4F9E-B013-DB10C82B6E26 (resized).jpegC1A5E94D-FC25-4265-B3DC-26D56AA61F41 (resized).jpeg
#346 3 months ago
Looks good but seems a waste of talent when it’s not visible to the player
#347 3 months ago
Probably. . In any case I made the final version and installed it today.
BBC12209-A78B-457A-9DBD-5E5FFC9F5495 (resized).jpeg12E8A6C7-B510-4037-A467-07D5C12E5C61 (resized).jpegF35CAC10-2C2B-41FB-B4EA-A911E5D8635D (resized).jpeg
#348 87 days ago
Does anyone have a lead on where I can get the race track boards? Marco sold out as is Mad Amusements. GLM obviously no longer making anything either, I need help!
#349 87 days ago
Do you have the original boards? They are easy to fix.
#350 86 days ago
Quoted from Kawydud:
I do but the encoder board is pretty trashed
8,900 (OBO)
Playfield - Plastics
Game Room Info Shop
4,995
West Chicago, IL
PinWoofer
$ 54.99
Indianapolis, IN
