Where can a guy lay hands on a lightbulb diagram for a triple action? Or any EM pin for that matter.
I'll clarify.
What type of bulb goes where. Flasher or non flashing.
I see that the flasher locations in the back box have a concaved slot, so that's easy enough.
Does the spinner have flashers as well?
44's 47's ???? What size flasher?
Deer and dolphins don't like each other.
Thank you for your time.
Pin
Schematics will sometimes specify a flasher. You've already found the concave cutouts. Other than that personal preference
Quoted from chad:44s work as do 47s, 47s have a bit less amps which equals a bit less heat build-up
People get wound up over the heat from 44s but in home use it is simply not an issue unless you just leave games on for some reason.
Quoted from EMsInKC:People get wound up over the heat from 44s but in home use it is simply not an issue unless you just leave games on for some reason.
Absolutely
44/47 pretty much everywhere. Occasionally the schematic will specify a flashing bulb in the backbox, but not always. And as you've noted sometimes the socket area in the backbox will be concave for a flashing bulb. Aside from that it is really a matter of preference how blinky the owner/operator wants the backbox to be.
I like to refer to them as blinkers, because the bulbs themselves are designed to provide the blinking. This is in contrast to "flashers" in the solid state world where the CPU sends a brief pulse to special lamps to accomplish the flash effect. When one says "flasher" most picture the solid state flashlamps and CPU pulses.
Here is a sample from Gottlieb Mini Cycle:
Credit to bintzknocker who shared in another thread. I now have an erupting volcano. Look for the socket that is mounted different than the others. For gottlieb at least.
Quoted from bintzknocker:On Jungle Queen the cloud above the volcano lights in game over.
FWIW, on Gottliebs, the socket that's mounted flush (or could be the socket that is sunk in) is the one that should get a 455. This socket will light in game over and provide a subtle attract mode.
This page was printed from https://pinside.com/pinball/forum/topic/correct-lightbulb-locations and we tried optimising it for printing. Some page elements may have been deliberately hidden.
