Hi Every one,
I recently bought a Data East machine Maverick that originated in Holland going by the start up screen and on the Power box in the cabinet. The plug on the machine is a stranded US 3 prong plug. I figured the person before me converted everything over to 110V. I have had the machine up and running and all but lots of burned out lights it all seems fine. On the Main fuse box it has 2 fuses and it says to use 5A Slo blow fuses. The Manual says for international machines it should have 2 4A slo blow fusees and for US machines it should have 1 8A slo blow fuse. I have read when going from 220v to 110 volt you should remove the 4 A and replace it with a 8 A. I also read some where if the machine has 3 flippers to replace it with a 10A. I'll attach a pic of the wiring inside the box too in case it might help. It looks like each lead goes to a fuse then out, would this be the same as putting 1 fuse there with twice the amps and take the other one out?
The Molex plug also looks like its wired as 100v The white wire is in the top middle hole and the jumpers are below it as well, I have attached a pic as well. I just wanted to make sure I should move the white wire and the jumper below it over. I couldn't fine where I can check the voltage at to see if this is actually 100 or 110.
Thanks in advance and sorry for the blurry pics.
