For Scott (and others that wish to do this). Note: This is not something someone just learning solid state should attempt, think before you do surgery on a game, it may die. For the foolhardy, please continue.
The nice part of this conversion is that you don't need a complete harness from a 7 digit game and it will work on any Gottlieb System 80 6 digit game without modifying the game ROM each time. Gottlieb used the exact same wire color assignments from 6 to 7 digit so you only have to pull 3 extra wires to the new displays. The part that takes the longest is crimping in the new connectors for the 7 digit displays.
All parts can be bought here (except the wire, zip ties and displays):
http://www.greatplainselectronics.com/
Parts needed: (2) 24 pin sockets Product ID: IS-624-MP
(1) U2/3 EPROM module with EPROM Product ID: 140-101 (sometimes out of stock)
(4) 7 digit displays
(87) Crimp contacts Product ID: 08-52-0072
(4) 24 pin connector Product ID: 09-01-6241
22 ga. wire
4" wire ties
First, remove both U2/3 from the CPU board and install two 24 pin sockets, then install GPE's U2/3 combo board in place and you'll need the 6 to 7 digit ROM (PM me about it). Along with converting 6 to 7 digit, it has free play available through the dip switch settings and also has quick boot (like 80A, no more 6 second wait at start up). Set both the jumpers on Ed's U2/3 board to the right (closest to the EPROM). The RAM will remember the new higher score with the new U2/3 just like before. You will have to remove the battery to clear all the audits for the new U2/3 to work since the RAM will want to remember what the old U2/3 told it, this will create a conflict.
That's all needed for the solid state board work. Now the 1's digit is working as a 10's digit, we just don't have a dead zero to look at now.
On the next post, the conversion will get a little harder. Any questions before I move on? I'll wait.
What_s_needed_A.JPG Socketed_U23_A.JPG Socketed_U23_C.JPG Active_1_s_unit.JPG
