I have a Mousin' Around that I'd like to put in public, but the coin door is a style that doesn't allow coins larger than quarters (the coin slot is part of the metal door, rather than a plastic piece attached to the reject mechanism). I also have a spare 3 slot WPC coin door, which according to the manuals is the same part number, and I would like to use. But the wiring appears different. The sys 11 coin door has a 3x5 connector and the WPC coin door has a 12 or 13 pin molex connector.
Is it possible to just change the connector on my better coin door and use it? If yes, how would I figure out the proper wiring placements in the new connector?
