Hello everyone,
I've been in the process of following Vid1900's "Bulletproofing a Williams System 7" topic and have run into an issue with my control lights. Per Vid's instructions I removed the TIP42 transistors on the driver board and replace them with IRF9640 (I know this is not the IRF he recommended), but it was what I accidentally installed..... yep I accidentally soldered 8 of these to the driver board..... (long story short, there was a mix-up I what was shipped to me). I've looked through the specs and I believe the 9640s will work ok, but I'm not 100% sure. After installing these Mosfets I jumped the gap where the old barrel resistors were, the ones that like to burn the board, again per Vid's instructions.
After that the playfield control lights worked for about a game and then stopped. Now none of the playfield control lights work at all. All GI lights work and I have checked the lamp fuse by removing it, testing it and then reseating it. I have also checked the voltage coming from the power supply board and it is registering at 16v. I also have 16v coming out of the lamp column drive pins.
However, I do not have any voltage at the lamp row drive pins..... should I? I'm a little fuzzy on how the lamps work as it relates to the columns and rows. How can I test or what should I look for as it relates to the lamp row pins?
Any help would be appreciated.
