Hello everyone,
I'm hoping I can get a few suggestions on what type of contact cleaner I should use. I'd like to clean some of my wire connections leading to the Driver Board and DMD. I have a TSPP and the DMD blacks out every now and again and also shows incorrect literature. I pushed the connectors in and it seemed to help for awhile, but now it just happened again. I turn the machine off and on, then it goes away. I think if I clean up some of the connections it might eliminate the problem.
P.S. I also ran a DMD test and it tested fine. I do sometimes see little scribble lines in the DMD picture.
