Ok the issue is fixed! All strings are working 100% and the machine looks great!
But I must humbly admit why. I come to you all with hat in hand and egg on my face. What did everyone tell me when I started this thread?
Quoted from Craigmack:Starting at J115 buzz out the traces from the header pins to the fuses, from the fuses to the traics and from the triacs to J120, J121 and J119.
Yes it was a fuse. I feel like such a bonehead, but before you jump all over let me explain. Earlier when I said I had checked the fuse I really had. When LTG asked if I had pulled it and checked I had in fact done that too. BUT I only pulled fuse F110 because in my manual that was the fuse that I thought was associated with the wire I had been having problems with the, yellow/white. I did not realize I needed to check the fuse asscociated with just the Yellow wire.
Why did I not check the other fuses? Because they are such a pain in the ass to pull. In fact I broke my crappy little yellow fuse puller trying to pull out that first fuse. I am always nervous pulling fuses that I will break something else with all the force. It was not untill I pulled the board again and followed all of the steps that johnwartjr told me to do did I realize that one of the other fuses was blown. So yes I am an idiot, but on the other hand I am a little glad it happened. I really want to learn as much about repair as I can and if I had just pulled all of the fuses first thing I would have missed out on some great things I learned.
1. Buy a fuse puller, a good one.
2. When there is a problem that could be a fuse, pull them all and check them all with my DMM. The fuse I pulled that was bad did not look blown at all.
3. I learned how to test the AC voltage on the wires.
4. I learned a whole hell of a lot more about how the GI works on williams machines and how I can thoroughly troubleshoot it in the future. Thanks especially to johnwartjr, that stuff from Clays guide was great.
5. I learned what triacs were.
6. I learned how to use my DMM to trace the path for one spot to another.
Thanks to everyone who helped me out. Special thanks to Johnwartjr, LTG, and Pinwillie for showing me how to fix the connectors in the first place. Thank you for your patience, hopefully next time someone has this problem I can help them and you guys can sit back and take a load off.
Lastly let me here some recommendations for a good fuse puller, not like the cheap plastic yellow one I had.
