I keep reading about getting 15 pin housings and cutting them, is there a tool for this? How do you guys do it?
Are the GPE value series housings any good or should I stick with molex branded...
I use a utility knife. Nothing special.
I personally have no experience with the value series housings, as I usually bought most of my stock of connectors from Mouser years ago before I really knew much about GPE. I'm sure for 99% of applications, the value series will be just fine. Might want to stick with the OEM Molex stuff for high temperature areas, like GI connectors though.
Quoted from CaptainNeo:you talking about block connectors or board connectors?
Cable end connectors, not headers.
Quoted from mbaumle:I use a utility knife. Nothing special.
Thanks. What size do you normally get? 20pin? That gets you two 9 pins at least for Williams games right?
Quoted from newmanoconnor:What size do you normally get?
Good question. I usually just stock up on all sorts of various sizes, but yea, you can't go wrong with the largest size you can get. I usually stock up on smaller sizes too, just so I don't have to cut and slice up so many different connectors.
While you're buying things, go for trifurcon branded female connectors. They have little "wings" that hug the sides male end of connector. They're especially good for GI wiring, as it maximizes metal to metal surface area and reduces resistance and heat which plague these games.
This page was printed from https://pinside.com/pinball/forum/topic/connectors-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
