I am having a problem with a switch column. Column 6 is not working. This includes the sling shots and the pop bumpers. I have found a loose wire, reconnected it. I have also found a previous “fix” where someone has attached a slingshot wire to the incorrect post on the slingshot. Should I keep looking for loose wires ( I cannot find any) or is it possible that the switch IC has been shorted due to the backwards wires on the slingshot. The diodes are checking out OK (assuming I am testing correctly ).
As always, thanks a bunch!
MK
