Hi there,
Was working on a small issue with my 2 way popper. All switches were fine.
Finished, tested some stuff and suddenly no more Row3. Appears shorted.
So I probably touched something and blew a component I guess.
Checked all switches from that row: no contact to ground
Continuity is ok to the small board below the playfield.
Any idea on what I should check/change?
Thanks in advance!
Edit: also checked the diod associated to row3 connectors on the small board below the playfield; tests ok
