(Topic ID: 50221)
CONGO CLUB....Owners Only!
By kidpinballwizard
10 years ago
Topic poll
“are you in the the club?(do you own a congo?)”
(0 votes)
There are 2,761 posts in this topic. You are on page 39 of 56.
#1901 5 years ago
Quoted from jawjaw:
Mine shot balls all over the place and was not consistent. It often shot balls right to the center of playfield. When I took things apart and gave it a good inspection, it did not look broken or bent in anyway. I went ahead and replaced it with the Mantis stack. When I removed the old stack, I noticed one of the mounting tabs was broken at the base. Once I had the new stack in things worked perfectly and never had another issue. It's relatively cheap to replace so I would just do it if you are having any problems in that area.
thx. ordering today
#1902 5 years ago
who sells the lane guide stickers that cover the steel lane guides?
#1903 5 years ago
Quoted from billsfanmd:
Treasure cove
#1904 5 years ago
These are way better then the stickers.
http://www.pinball.center/en/shop/pinball-parts/playfield-parts/plastics/3956/lane-plastics-for-congo
#1905 5 years ago
I just picked up a Congo and the lower playfield had yellow led's in it. I did the rest of the game in Comet day lights. Curious what other folks have done? The yellow gives it a semi erie feeling but am I missing artwork without the day lights? Any other cool schemes that people have done? Please show
#1906 5 years ago
Quoted from Yesh23:
i also lit the lower playfield GI with Comet frosted yellow/ambers and a purple each side at the rear (nearest the gorilla).
Also use GI OCD because Congo has some excessive GI dimming!
#1907 5 years ago
Quoted from monkeyboypaul:
Do the purple add much by the gorilla? What does the GI OCD board actually do? I have Comet Daylight 2 way frosted in all the GI's
#1908 5 years ago
Quoted from Yesh23:
Congo's GI dims quite a lot, as designed for incandescent bulbs, unless it's disabled in the settings.
LEDs will flicker instead of dimming. GI OCD adapts your machine's dimming circuitry to allow LEDs to dim correctly, behaving like bulbs. The cheapest way to restore 'as factory' dimming is to use incandescent bulbs again as GI OCD is not cheap, but works well if you want to us Leds in the GI AND have the dimming effects.
http://ledocd.com/faq_gi.html
See 5mins & 7mins for 2 quick examples of a Congo dimming with incandescents.
#1909 5 years ago
Quoted from Yesh23:
I used comet frosted yellow bulbs in lower playfield. Last two sockets close to guerilla I used purple flex bulbs to shine right on guerilla. I also used sunlight for gi and really like how it looks.
#1910 5 years ago
Quoted from jawjaw:
Great idea using the flex bulbs. Do you have any pictures of how it looks?
#1911 5 years ago
One last question. When you lock the balls in the volcano and you start multi-ball does everyone's balls hit the top of the glass? Mine seem to hit the glass fairly hard and I didn't know if my coil was firing too hard or if that was common
#1912 5 years ago
Quoted from Yesh23:
Definitely not meant to happen. Guess check the VUK coil's voltage?
#1913 5 years ago
Quoted from Yesh23:
Your VUK is knackered! Specifically the top lip that slows & diverts the ball. Get the reinforced Mantis version.
https://mantispinball.com/product/congo-volcano-weldment/
#1914 5 years ago
Quoted from Yesh23:
#1915 5 years ago
So why is a gorilla purple?
#1916 5 years ago
Grape ape? I know, clown puke police will write me a ticket. Tried some things but wasn't happy with it.
#1917 5 years ago
I've struggled with that area too. I've tried white, yellow, orange, red, purple, and even fire/flame. Right now I'm using orange bulbs. I thought the purple might work since it was inside of that purple colored temple, but it drowned out the orange lava. I may order some more flexes and play with that a bit. What I ultimately want is for the surrounding area to have a purple hue to match the temple on the playfield, but to still see the orange lava and grey gorilla. What I'm considering trying next is to have the GI all purple, but add white from behind the gorilla and behind the target bank.
#1918 5 years ago
Quoted from jawjaw:
Looks great. I think you have me sold with the purple
#1919 5 years ago
One thing weird about my game is I had to put an incandescent flasher behind the guerrilla. A led flasher would flash when I hit the flippers for some reason. Same for one flasher in the backbox.
#1920 5 years ago
Quoted from jawjaw:
Snap! Must be a design flaw somewhere.
#1921 5 years ago
Quoted from jawjaw:
That’s not a misdemeanor, that’s a felony!
#1922 5 years ago
Quoted from jawjaw:
Same thing here. Didn't realized it doesn't do that with incandescent.
#1923 5 years ago
Quoted from jawjaw:
What about blue to match the blue gorilla insert
#1924 5 years ago
Quoted from ufiti:
I guess it's not just my game then. I had to work out a lot of issues with my game so wasn't sure if something was still screwy. Put an incandescent in there and it will work correctly. I forget which one in the backbox did it as well but regular incandescent works correctly there as well.
Quoted from Mitch:
I don't really like blue leds for some reason. Might try ice blue from comet. I've been trying to get an order for comet bulbs but they have been out of stock of one bulb I need for weeks. I love comet but seems like every time I order there are bulbs out of stock.
#1925 5 years ago
I did some playing with the colors on my lower playfield. I ended up with all orange with an LED strip behind the gorilla. I'd still like to try to find a way to make that purple in the playfield artwork to stand out more, but so far I haven't had any luck. I may try mixing in some white flex bulbs, but I didn't have them on hand.
#1926 5 years ago
Lighted Magnetic Hinge Covers limited edition available for Congo, just 5 minutes to install! Pick these up on our Pinside store, or through our website:
https://pinside.com/pinball/market/shops/1032-lighted-pinball-mods/01755-congo-lighted-magnetic-hinge-covers-yellow-limited-editon
ad3529a1db363be7503957e507eab35c55209c46 (resized).jpgad3529a1db363be7503957e507eab35c55209c46 (resized).jpg
You can get these in any of the 8 available colors, however our red is a deep blood red when on and is highly recommended for Dracula!! Because this is the most common color we stock, we offer a discount of 10.00 for this color.
[lighted_magnetic_hinge_covers_pinball_EL_panel_mod_ (resized).jpglighted_magnetic_hinge_covers_pinball_EL_panel_mod_ (resized).jpg
Many titles and designs available, check out our store and search by game!
lighted_magnetic_hinge_covers_pinball_EL_panel_mod_iron_maiden_guardians_of_the_galaxy_star_wars_aerosmith_pinball_mods (resizedlighted_magnetic_hinge_covers_pinball_EL_panel_mod_iron_maiden_guardians_of_the_galaxy_star_wars_aerosmith_pinball_mods (resized
If you can throw a magnet on a fridge, you'll be halfway done with the installation of this Mod! No permanent game changes, and easily followed written and video instructions provided. All hardware, power adapters, and everything needed for installation is provided. Our customer service is top notch in the industry.
twilight_zone_pinball_mod_lighted_magnetic_hinge_cover_EL_panel_LED_lighting_custom_pin_diy_repair (resized).jpgtwilight_zone_pinball_mod_lighted_magnetic_hinge_cover_EL_panel_LED_lighting_custom_pin_diy_repair (resized).jpg
#1927 5 years ago
Anyone else get airballs off the left ramp that bounce over the "RELIGHT KICKBACK" plastic and straight out the left outlane? It used to only happen very rarely for me, now much more often.
#1928 5 years ago
How does that work? The ball should go up the left ramp and hook down right? I can't picture the ball deflecting down left. Is your ramp flap bent up? There also should be plastic cover over the back part of the ramp in from of the guerrilla.
#1929 5 years ago
It looks like the top of the lip is busted off. I couldn't find in the manual how the above assembly is installed but if I click on the link, it looks like it's straight up and down and doesn't have a lip in the picture.
#1930 5 years ago
Does anyone know where to get the decals for each of the sides on the lower playfield?
#1931 5 years ago
Quoted from Yesh23:
Your VUK is destroyed and it broke the top of the volcano too. My volcano is broken too but I have the new mantis vuk works awsome.
15391339796067038895992479259992 (resized).jpg15391339796067038895992479259992 (resized).jpg15391340351264671481718246861021 (resized).jpg15391340351264671481718246861021 (resized).jpg
#1932 5 years ago
Quoted from Yesh23:
Planatary pinball but not cheap
#1933 5 years ago
Luckily I have a nos volcano
15391341602546666084676298620027 (resized).jpg15391341602546666084676298620027 (resized).jpg
#1934 5 years ago
Quoted from Mitch:
#1935 5 years ago
Quoted from Mitch:
Make sure you install the new and improved mantis volcano scoop if you ever install this NOS volcano ramp in your game.
#1936 5 years ago
Quoted from jawjaw:
To clarify, the ball isn't going up the ramp at all, it is bouncing off the standup target at the bottom. Pretty similar to the Ghostbusters airball issue I think.
#1937 5 years ago
Quoted from ufiti:
Check the padding behind the switch face. The back plate might be bent back as well. I had that problem on my Shadow and got reinfoced targets:
https://www.marcospecialties.com/pinball-parts/A-18530-6R
You can try to bend it back straight and use extra padding.
#1938 5 years ago
Quoted from jawjaw:
Thanks, I'll try that! The padding does look pretty beat.
#1939 5 years ago
Quoted from Mitch:
I didn't seem to find it on Planetary's website, any other ideas?
#1940 5 years ago
Quoted from Yesh23:
a quick google search " congo lower pinball decals " found this
http://www.ministryofpinball.com/en/game-specific-items/williams/congo/congo-mini-playfield-decals.html
#1941 5 years ago
Thank you Mitch for the find. Unfortunately they're out of stock right now
#1942 5 years ago
Quoted from Yesh23:
Damn, sorry I didnt notice that. I'd send planatary pinball a email see of they are making more maybe?
#1943 5 years ago
Quoted from Mitch:
Thank you, just sent email
#1944 5 years ago
I'm in too.
One of the most underrated pin and film ever.
Reason enough to buy one.....and in very very nice condition!
20181020_165256 (resized).jpg20181020_165256 (resized).jpg20181020_165309 (resized).jpg20181020_165309 (resized).jpg
#1945 5 years ago
I've had my Congo for over 5 years now. Its one of the nicest i've ever seen. I love it dearly, but it doesn't get played much anymore. I think what keeps Congo from being one of the best pins of the 90's is the lack of modes and a story or ending so to speak to shoot for. Now its all about just trying to beat the diamonds collected or the high score which on my game is over 5 billion. I keep telling myself its time to move on from it, yet i just can't. I'm curious if anyone else has felt this way? Just when I think i'm ready to let it go, I play it and just can't bring my self to part with it.
#1946 5 years ago
Quoted from Squeakman:
Same
#1947 5 years ago
Quoted from Yesh23:
I printed my own with the files that were posted earlier in this Congo thread. I used Papilio vinyl in my inkjet printer. It took a few trial runs to get the scale just right. I think I may used a clear mylar over them.
#1948 5 years ago
yup. almost tradded it several times glad i didn't. the valcano shot is so satisfying . my personal best is 34 consecutive volcano shots!
#1950 5 years ago
Quoted from freddy:
$ 89.99
$ 27.50
$ 31.99
Lee's Parts
Colorado Springs, CO
$ 54.99
$ 39.50
Drums, PA
$ 9.95
KAHR.US Circuits
$ 32.95
$ 12.00
Pinball Invasion
Dickinson, TX
$ 89.99
$ 37.99
Lee's Parts
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/congo-club-owners-only/page/39 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
