OK, so here's the issue I've been having with my RS. Hope you guys can help.
When making the right ramp shot, the ball is (not always but sometimes) supposed to get diverted so that it comes down the left side feeding the mini flipper for the blast zone shot. But what happens with mine is that the ball does not make it all the way around the back rather, it bounces off the center of the plastic at the fork, then rolls back down the wire form to the right flipper.
As a temporary fix and to avoid further damage to the plastic where the ball hits, I've enabled the diverter for all right ramp shots. This works ok, but I'd really like to solve this problem.
My initial thought was that the left flipper coil was not strong enough to send the ball all the way back and around, but I don't think that's the case as it's the correct sized coil and it seems pretty robust. Also, from what I can tell, the ramp is installed correctly--nothing seemingly missing or out of place.
I really don't know what is causing this. Is anyone else experiencing this issue or have any idea why might be causing it?
Thanks in advance.
-Boo
