Quoted from BDAWG:ok fast power cycles got it up but the batteries were toast.
should it be playable doing this method? cause mine is not.
is there a write up or video showing how to put a lithium battery in place?
That only got it to attract mode, now you have to get a credit (insert coin) and then start (button on front of cab).
Comet does not require a ball to go into game mode, since there was only one ball to begin with (a common problem with multiball games is no start without all balls). BUT a slam tilt stuck closed will stop the game from starting after credit up.
Once you fix the battery problem, you can set other options, including free play.
You can NOT set it to free play currently, since there are no batteries, and without batteries, no settings are saved....
