I'm a bit confused....He removed the offending coil and taped off the wire. Therefore, it's not the transistor causing the fuse to blow at this point, as even if the transistor is locked on (bad), there's no load any longer to blow the fuse. Sooooo....You've got more than one problem, amigo.
Not saying the transistor isn't bad and you should follow Mike's advice to troubleshoot, but if you have the coil removed, then you're still going to have the same problem as something else is causing your fuse to blow. Is the game blowing the fuse while sitting in attract mode or only during gameplay? When you turn on the game, you need to pay close attention to any coils activating and staying on. Lift the playfield while the game is on and carefully check each coil to see if one is getting warm/hot...If it is, you've found another coil with another bad transistor.
Were you doing anything to the game when this behavior started?
