So I've had a problem with my right kicker (sling) locking on with my Comet. I've posted about it in the club thread and decided to start a new one for my problem so I don't clog the club up.
As soon as I turn the machine on, the right kicker locks on and stays on. So far I have
-replaced the driver transistor Q77
-replaced the pre driver Q78
-replaced the IC chip U7
-inspected and removed leaf switches to make sure they are not making contact
-tested the diode at the solenoid
-looked for pinched wires
-replaced the solenoid with a known working one (the knocker)
Nothing is working. When I intitally pulled the leaf switches from the playfield and just let them hang there it worked for a few minutes. Then there was a hum and it locked on again. After that I completely took the switches off the circuit and it still locked on. Soldered them back on and still locks on.
Right now I am getting a reading of 3-5 volts from the collector of Q77 when I turn the game on and I am getting 20 volts from the other transistors that run the pop bumpers and other kicker and none of them lock on.
Any suggestions?
