Looking for feedback on the Comet DMD Glare Guard... Looks like an easy install! Wondering if the DMD brightness is greatly affected?
Any opinions would be appreciated!
Very easy install. They work great! I use them for all my DMD pins. It does darken the DMD a bit. I find it a total non-issue with a color DMD since you can change the brightness settings.
Also, newer Stern DMDs are very bright so I don't mind it darkening it slightly. It might be an issue to some with the lighter orange dots.
I can't remember where I got my glare guard but it is awesome. It's the same kind as Comet based on privacy screens. I think I noticed it took a little off the brightness but in all honesty it looked way better. It kinda just softened the brightness just a touch. Highly recommend the product the upper part of your pin goes from like an old CRT to HD.
I still prefer this product: http://www.pinballlife.com/index.php?p=product&id=3301
Cheaper, non-intrusive regarding the DMD brightness, none installation needed at all, and it prevents reflection from both the DMD and the BG lights onto the PF....
I think results will be slightly different on each pin. I would just tape a piece of cardboard over the DMD on you pin. Or have someone hold it up and take it away while you stand where you would when playing.
I ordered these and was somewhat skeptical but turned out to be shocked at how well they work. If anyone is on the fence on these don't hesitate to get 'em. Remove the DMD from your game and simply apply with the 2 sided tape on each end and reinstall. They do dim the DMD ever so slightly but I think it actually improves the overall contrast as a result. Amazing results for just $15!
This page was printed from https://pinside.com/pinball/forum/topic/comet-dmd-glare-guards and we tried optimising it for printing. Some page elements may have been deliberately hidden.
