(Topic ID: 259140)
Switch Column issue on Comet
By yaksplat
46 days ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 45 days ago by yaksplat
#1 46 days ago
Any time a switch in column 5 is closed, all of the switches in that row register in the tests. So if i close switch 36, all switches in row 3 report being closed. What am I looking for here? I can't find any shorts in the wires, all diodes are soldered correctly and this was previously working on this machine.
#2 46 days ago
The switches you highlighted in that column.Work your way upstream starting with the first switch in that column which Would be switch 33 left standup switch look for a loose wire and a bad diode on one of those switches in that column(your problem sounds more of a bad/faulty diode or a switch is wired in the wrong order).
Where you working on the game such as wiring on a switch Or replacing a diode?
#4 45 days ago
Quoted from pinmike:Where you working on the game such as wiring on a switch Or replacing a diode?
I just put a hard top on the playfield. This whole group of switches was hanging under the playfield for a bit while I sanded and rebuilt the top, but none of them were disconnected. I'm a mechanical and software guy, so I'm still a rookie with the electrical side of things. This helps though. I'll check the diodes and wiring in that order. Thanks!
#5 45 days ago
I went through and tested every diode and they're all testing correctly in both directions. I then started testing continuity around other switches and i found that GRN/BLK is shorted to all other WHT/* wires. I took the connectors off and it's happening at the board. Should that happen?
$ 50.00
1,000 (Firm)
Sterling, MA
$ 17.00
$ 29.95
$ 400.00
Playfields
Maple Street Sign Shop
ScottyMods
$ 9.00
Hdmike mods
$ 12.00
Meph's Mods
$ 79.95
$ 99.99
$ 74.00
Id Rather Play Pinball
$ 239.00
€ 18.95
$ 11.00
Third Coast Pinball
$ 119.95
Allteksystems
$ 27.95
MicksPinball
