Edit.. The 3mm version is rated for playfield lift if a diffuser panel or clear lift panel is installed. The 6mm version mentioned in this opening post is not being produced due to excessive cost.
Coming soon to redshiftLED, coloured aprons in solid, translucent and tinted acrylic. There will be two versions. A 3mm thickness version that is NOT rated for playfield lift. Impact and wear are fine, but lifting will put too much stress on some of the sharper bend intersections that may then crack. There is a super strong 6mm version that frankly looks like an art installation at the MoMA. They are gorgeous, and are fine for playfield lift. They will be in fewer colours, will be more expensive, and may not even happen due to the minimum sheet quantity I have to order.
For lighting purposes there will be an optional diffuser panel that is the same shape as the top surface of the apron and can be easily glued underneath, with glue spots where your cards go.
They will fit pro or premium Sterns. On a pro, take out the current apron mounting posts and screw the new one into the playfield hooks at the bottom end of the playfield. If you have apron mounting feet as on Whitestar machines, then you will use a 3mm spacer to lift those feet to line up with the slots on these aprons that are a bit higher, or just remove the feet completely. You will not need them as you will not be lifting your playfield using this apron.
This is not a launch per se, but here are some pics. More will follow next week some time.
Price will not be more than US$75.
