I’m experimenting with ColorDMD Sigma Color Changing and getting some unexpected results. I have 5V connected to “+” on the ColorDMD’s Lamp-In connector and, using an Arduino, I send a PWM signal (a value from 0 to 255) to the G, R, and B pins. If I set a value of 255 on all three pins, I see the display’s normal color (I have my ColorDMD set to “50”, a nice bright purple). When I send a value other than 255 to G, R, and B, I get a dim color. For example, if I set the values to 0,0,0, I don't get bright white (I get a not-so-bright cyan). I’ve tried many different values for G, R, and B. Instead of seeing a wide range of colors, I just see a handful of dim colors.
So my question is this. What PWM values do I need to send to the Lamp-In connector if I want to see nice bright colors on the ColorDMD? Like a bright yellow, or white, bright green, etc. Or is it even possible?
