ColorDMD Issue in X-Men LE
By mettle64
9 months ago
Stats
  • 25 posts
  • 9 Pinsiders participating
  • Latest reply 7 months ago by TigerLaw
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
There have been 9 images uploaded to this topic. (View topic image gallery).
#1 9 months ago
I'm brand new to the hobby and just had an X-Men LE shipped to me. Unfortunately I'm already running into issues. It's got a ColorDMD (1.3) installed and power is getting to the display, but there is no evidence of a video signal. Based on the ColorDMD support page I've confirmed that the ribbon cable is oriented correctly and I've also reseated it. I've reinstalled the appropriate ColorDMD code just in case there was an issue there.
Being new to the hobby I don't have another machine to test with or even another DMD to swap in for troubleshooting. Reaching out to ColorDMD support brought me to the conclusion that this may be an issue with the CPU board itself. I don't see any indications of damage to the board, but I'm not sure where else to focus.
Is this likely an issue with the CPU board? Something repairable by an expert?
#2 9 months ago
Does the game start up and play? If not then its probably not the display and something else like loose connectors or defective parts.
#3 9 months ago
Hey, thanks for the reply. Everything else in the game works just fine. Gameplay, lights, audio, etc. Just no output on the ColorDMD.
#4 9 months ago
I would backtrack through the install directions to see if there is a simple connection issue. In pinball, it's usually the simplest thing that's causing the problem.
Is there power to the color DMD board when the game is on? There should be some lights on the back side of it that come on.
If not, check the connection that is run to the front right side near the power supply near the coin door.
If you have power, then try reseating or flipping the ribbon cables to the color DMD.
#5 9 months ago
Please post a picture of everything connected. Can you post a picture of the screen when you press the menu button as well?
Did you install the Chroma file for Xmen? Should had been from this support page. http://colordmd.com/support_firmware_chroma.html
What size USB stick are you using?
#6 9 months ago
Edit: Nevermind, re-reading it sounds like you don't have the original DMD.
#7 9 months ago
Also, did you disconnect the power cabke from the right side of the small DMD power board in the backbox? If so, connect it back and see the results.
#8 9 months ago
Make sure you power connector (red and black) are oriented correctly.
#9 9 months ago
I really appreciate all the feedback. I've tried to answer everybody's questions and I'll attach some photos as well.
Also, I've discovered an orphaned plug with space for 6 pins and 1 blank in a 2-4 arrangement and included it in a photo. Anybody know where this should go?
Quoted from Guinnesstime:
I've backtracked a few times with no luck.
The ColorDMD is getting power. The 'Done' LED lights up on the back and I'm able to get into the menu system.
I've reseated the ribbon cable a few times and just tried flipping it just in case. No luck.
Quoted from PinballManiac40:
See attached photos.
I've installed the older version of X-Men code, not Chroma, since this is a 1.3v ColorDMD.
I'm using an 8GB USB stick formatted to FAT32. Code installs (Sigma and X-Men) haven't fixed the issue but also haven't raised any errors on their own.
I think you're referring to the DMD high voltage board that is required for plasma DMD displays. X-Men shipped with an LCD DMD so this board isn't included and isn't required (that I'm aware of) for installation of a ColorDMD. See attached photo of the contents of my backbox. If I'm misunderstanding, please elaborate.
Quoted from IceCreamMan:
Triple checked.
#10 9 months ago
Ok. In any case you are getting power to the ColorDMD board. Can you show the info screen? I can see a part of it, but just wondering what file is currently loaded.
#11 9 months ago
See full display.
#12 9 months ago
Can you flip the ribbon cable around just at the display to see what happens?
#13 9 months ago
Was the display working in the game before it shipped to you?
It's rare but it's possible there's a problem with one of the DMD inputs on the ColorDMD board... or the Xilinx chip could be damaged. Is the large chip in the center of the board getting hot?
#14 9 months ago
Yes do this. I did this with my IJ and it did the trick.
#15 9 months ago
I purchased a stock Red LED DMD from Pinball Life to determine whether the issue is with the ColorDMD or the Pinball board. But to get power to it I need one of these cables, which I'm having trouble positively identifying or finding for sale anywhere. Any ideas?
#16 9 months ago
Quoted from mettle64:
Getting power to the ColorDMD does not seem to be the issue that you were having.
Quoted from Dmod:
Can you snap a picture of the ColorDMD board so Randy can see if the chip is damaged?
#17 9 months ago
You're right, but I can't confirm whether the root cause is the ColorDMD or the Stern board unless I can power the stock Stern LED DMD. The cable used to power it is different than the one used to power the ColorDMD.
#18 9 months ago
Didn't the game come with a red LED DMD and was playing fine before installing the ColorDMD?
#19 9 months ago
OP mentioned in the first post that the game came with the ColorDMD when he bought it.
#20 9 months ago
If you would like to send in the control board from your display, I can test it here and let you know if there's an issue with the board. Email info (at) colordmd.com.
#21 9 months ago
You should contact the guys at ColorDMD. I had a problem and they walked me through all the troubleshooting steps. When that didn't work they had me send the board back and fixed it right away.
#22 9 months ago
Quoted from Dmod:
I really appreciate the offer, sending a PM soon.
#23 8 months ago
Randy was able to confirm the ColorDMD is functional and the fine folks at Marco Specialties were kind enough to cobble together the 5v cable I needed to power my stock LED DMD, which still displayed nothing. At this point I'm convinced it's an issue with the CPU board so I'm planning on calling Stern's support on Monday.
1 month later
#24 7 months ago
Just to circle back on this in case someone runs into a similar issue in the future.
Sent the CPU board, display, and ribbon cable to the fine folks at Game Exchange in Denver and they confirmed an issue with the CPU board. Initiating a repair and going from there.
#25 7 months ago
OP, what is that weird bubbling around your display?
$ 69.00
...redshiftLED
Bright Lights Pinball
6,000 (OBO)
St. Louis, MO
$ 48.00
$ 170.00
Pin Mods
Professor Pinball
Professor Pinball
5,800
Sale Pending!
Marshville, NC
$ 160.00
Professor Pinball
$ 12.00
Pin Mods
Lighting - Backbox
$ 8,500.00
PinballSTAR Amusements
$ 45.00
Apparel - Unisex
Double Danger Pinball
Note: This is an old thread. The last post was made to it 218 days ago. Resurrecting old threads is not necessarily a bad thing, if you think the topic is still relevant and/or your post is beneficial to it (e.g. following up on something). In other cases, it might be better to create a new topic.
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
