Quoted from luvthatapex2:The way it always works for me updating the display:
1) download the rom (chroma.rom in your case since you are using a new display board) and copy it to the usb stick. This should be the only file on the usb stick.
2) turn off the game. insert the USB stick. turn on the game.
3) once booted, hold the first button on the left down down and watch the display board blink 5 times. This is the button closest to the ribbon cable. It should start downloading the rom and you can leave go of the button. The display will now be BLACK as its getting updated, then around 45 seconds later, the display will turn on with the color rom loaded.
This video from color dmd shows the process. start at 1:17 to update the display. again disregard the filename in the video, you need the new chroma.com, but the rest should be correct.
Thank you very much! I wasn't aware that the chroma file has to be the only file inside the usb. I tried 3 different usb's and all have words files in them. So I have to buy a new usb for this? I cannot delete my files because I need them.
My first color DMD I bought was for a Getaway. If I'm not mistaken, the usb I used had other files in it and I had no issues. I will try your method. Thanks!
