After having the Color DMD in my TZ set to black/white for a while, I decided to update it to the latest firmware and try out the TZ color ROM again. What I am consistently seeing is that the image flickers between color and white. This happens in attract mode (e.g. when the TZ logo against the same background as on the cabinet side art, scrolls off the screen to the left - but note that flickering is not always present when it scrolls to the right), during some (but not all) piano or slot machine animations, and other in-game animations. But the kicker is that presence of flickering does not seem to be limited to animated frames. For instance, when you get the extra ball, the animation ends with a static image of Tina with the words 'extra ball'. Even that static image is flickering between color and white.
I have had this issue since I got the Color DMD, which was in part why I switched it to black/white. I did see another thread on Color DMD flickering issues (here: https://pinside.com/pinball/forum/topic/flicker-in-color-dmd-on-white-water) mention to reseat the ribbon cables which I did, but that did not seem to have an effect.
Has anyone seen this before? Is there anything else I can do to try to resolve this, or is my only recourse to reconfigure the ColorDMD back to black/white?
